The Unofficial DongDongHai(DDH) info thread and the Dongers lounge ;)
Good point I haven’t seen a Picture of a D2jC with a different tube yet.
However the Newest host N2A does have the same threads so I’m hopeful.
Also the D2iC is still available from 1 shop:
https://e.tb.cn/h.jiBMo7XA09ix7YW?tk=MSQq62G77oc
I “looks” like a hank style button, but is the threading going to be the same as a hank button? I assume it isn’t.
I much prefer the d2ic because I can use a hank rubber button and ring.
Don’t know about the thread size. But if the threads are bigger then these buttons might fit the new Convoy S21E. Also L21C will come with the same design button.
The 47mm v4.2 driver has essentially the same firmware as the 32mm v4.25 driver. Where you can disable FET and set different levels for the max buck, and the Anduril like UI.
The N2A with a 26105 tube is a vibe
Does anyone know where to get a 26105 li ion for europe? I found them on taobao but i not sure if i can ship them through superbuy. Also, can the 32mm v4.25 driver handle 2s? Thanka for any help!
https://flashlightgo.com/products/weltool-inr26-110-full-tab-lithium-ion-battery-3-6v-11000mah?variant=45683463028885
I ordered two from this place to the us, everything went smoothly. 26110 size works in the DDH 26105 tube
If you’re lucky you might have it shipped through superbuy without buying the finished flashlight.
Edit
This might also work
Similar vibe with the D2IC
