I have to say I didn't expect I would like this light. Looking at in the packaging, it appeared that the head would be too narrow for my taste. It also looked like it would be made of thin material. But when dchomak offered some at his cost, I couldn't refuse. At a minimum, it would I would get an XPL and some parts. Turns out I was wrong. Due to the design and dimensions, there are all kinds of mod opportunities in this light.
Dchomak first alerted and tore down this light at Posts 3 & 4 in this thread. The light has a thick walled battery tube that doesn't need to be bored to take unprotected King Kongs. Two will fit with a spacer. The fit is snug, but they slide easily. No rattle. The head has a 2" (50mm) OD reflector and lens. This means that reflectors that fit in D & C Maglites, SRK's, 3T6's, etc should be easy to fit with light filing. Not sure if any readily available glass lens options exist though. Not an issue if you cut your own glass or don't mind grinding one down to size.
The reflector is plastic, but appears to have a very good quality finish. Looks designed for throw. The light has double O-rings throughout and appears to be water proof to shallow depths (I didn't test this though) The battery tube is a little slippery. Gonna try to lightly dull with high grit sandpaper.
Head and tail. They have lots of machining and all appears to be done pretty well. Due to the design, it would be easy to extend or shorten the head. A 18650 will fit all the way down into that tail. If the switch was pulled, an 18650 will go all the way to the bottom. This provides enough length to fit 3 18650 cells.
Head was lightly glued. See that stuff to the right of the first pic below. That was the glue. I used a hair drier (not a hot air gun), a strap wretch, and a silicon oven mitt to unscrew the head.
Inside of the head. The pill top is flush with that bottom landing. The two halves of the head could be cut to shorten the head. Or a spacer (or cooling fin) could be inserted where the two halves meet to extend the head.
Reflector is looks real good to me. About 44.5mm tall, 44mm ID, 50mm OD.
There is a nice channel that an O-ring can be put in to have a small bumper. The light is a nice size. Would prefer a side switch. Thinking about trying to put one that is vertical (thumb is pointing to location I'm thinking of).
Tail cap assembly seem hardy. By the way, that wire in the spring is stock.
Mods to come. Just need to decide which direction to go. :)
