Have to say it’s one of the worst headlamps I’ve used. Received two units as an ex dealer and wasn’t impressed at all. Super uncomfortable with the mount being hollow, one unit had the glue fail inside that holds in the switches, both units had the USB cover open up in use.
If you stand on the headband winder or take a nasty fall, it could break leaving you with no way to tighten it. I also found that just the right tightened fit was in between a notch in the winding mechanism, and if used on one with long hair, well, you can imagine how much an issue that would be.
