Hi,
A bit of a long story…
Still new, so earlier, I was reading (don’t remember where) that IMR batteries were good, because they could supply high current(?).
So anyway, I found some on Ebay recently, and picked up several.
As I said, I’m still new/learning, and I had been trying for awhile to try to use a rechargeable battery in a “TechLite Lumen Master 250” that we got from Costco, in place of the 3xAAA carrier, and, in particular, an 18500 for the added capacity.
I had some problems the 1st try, apparently due to a bad 18500, so I just got a new IMR 18500 in today, and put it into the light, and it worked fine.
So, I figured I’d leave it on high, to see what kind of runtime I’d get.
Awhile later, I noticed the light was off…. Oh, oh :(….
Removed the 18500 and checked the voltage and it was good, so let the light sit, then put the 18500 back in, but still wasn’t working.
Put the original 3xAAA carrier in, and light still not working.
At that point, I figured that I’d fried the light.
But, I guess I’m kind of stubborn, so I happen to take the tailcap from another same light and put it on the apparently dead light, and VOILA, it worked!!
So, it looks like I killed the tailcap??? I didn’t think that was possible? Isn’t it just a mechanical switch?
Also, I’m theorizng that using the IMR battery may have been a bad idea, i.e., because it can source higher current (vs. 3xAAA or a “normal” protected 14500 I had tried earlier this week) to the light, maybe too much current, such that it fried the tailcap/switch?
Does that make sense?
Also, I haven’t done much disassembly, but is it possible to fix that tailcap/switch?
Thanks, and sorry for the longish post.
Jim
P.S. Thank goodness these lights came in a 3-pack :)!!
