“giorgoskok wrote: Nice work KWB !
I’m tempted to get one now , and mod it with xhp35 hi and maybe a R018 (R008+R010) resistor …”
If you stack an R008 and R010 resistor you will NOT get an R018 value, it will be R004444 (0.004444) and WAY below what you’re shooting for, might just be enough to kill your driver.
mmalive said………
[quote=BTW, pretty good throw but pales to BLF GT. Anyone done test shots against the top throwers?
Like Nitecore Tiny Monster, BLF GT, etc…[/quote]
Whole different category of lights you are talking about there really.
Kind of like comparing a C8 to the TN42 or something.
For the size reflector it has and the lumens output the Catapult V6 does very well. If you have , or are familiar with the Acebeam L16 (listed 2000 lumens with just under C8 sized head) and also uses the XHP 35 HI , then it actually out throws that one by a fair amount and has a tighter hotspot.
Although pictures taken in different seasons …… Here is the L16 at 100 yards from gate and then the V6……… also at 175 yards from big tree…………
I can’t help thinking from what I’m seeing from my T/A light tube that these are E2 binned emitters in the Cat V6. Maybe just for the first few to make a statement, shock and awe……who knows? I have many XHP35 lights, most are E2 or E4 and this little bugger is right there with some of them! :person_facepalming:
I know what you are saying with this.
I took one of my Maxtoch M24 that I put a dedomed XM-L2 U4 1A in and a 4.5 amp driver (up from the original 3.4 amp or so driver) and was expecting the M24 to have a lot more throw than the V6 at my 400 yard marker.
I was very surprised that the V6 is holding its own out to that distance to be honest with the M24 , but it puts just about the same amount of light on target as the M24 does at 400 yards , even though the V6 has a larger hotspot and broader spill.
Keep in mind also the M24 has a 54mm reflector in it where the Catapult V6 has around a 49 or 50mm reflector. The reflector on the M24 is also 12 to 14mm deeper than the V6.
With the tighter beam and at further distances , the M24 should start out throwing the Catapult I think , but I will have to get out to my 500 and further out markers to see what theV6 does on out there , but as I say at 400 yards the V6 is doing very well.
Here is the comparison shots taken at the same time with those 2 lights at 400 yards. First is the actual picture and the second of each is with the hotspot area enlarged , to see better the trees and white marker down there.
Ah Giorgos, leave it to a Greek to turn my way of thinking upside down! (Never used series resistors before.) LOL
Y’all convinced me to revisit the Thrunite store and once again I added this V6 to the cart, only to back out one more time! I really do like this one, it’s just that it falls in between categories and there are other things I’m looking at, namely the crazy expensive Luminous CFT-90 emitter.
Thinking I will have to pull the plug on that powerhouse 90 and build a light to put it in, which would be my 8th. Probably a 4P carrier to get run time at the power levels required, or at the very least an 32650 for it’s superior capacity, then again, the 40T may be one of the only cells out there that is capable of really pushing this emitter… 3P 21700 maybe? There goes any idea of budget, $115 emitter and triple $25 cells, aaaaagghh!
Just get it from HKEquipment, as I mentioned earlier in the thread - 60 euros including free shipping. They’ll no-doubt have the NW version once it arrives.
This falls into my wanted list and I have a NW one in my cart on their site for $59.99 w/free shipping, quite fair I believe.
Butt I have the Emisar D1S and D1. I checked the other night and actually the D1 provided adequate at the distances at our location on the bend of a creek 2 miles from the coast with steep hillsides. If I were on a coastal view site, I would not hesitate.
