ThruNite NW TN30 Broken
Hi guys,
I have a ThruNite NW TN30 has to be about 4 years old but only used for about 30 minutes.Spent most of its life in the metal box it came with under my desk.
I went to turn it on the other night and nothing. The 3 leds have a faint glow and that is all.
I am after someone in AU to fix it for me for their fee. Maybe you guys might have seen this fault before,
and be able to let me know if it is worth fixing or not.
Cheers.
You did use new cell’s in it, right?
Hmm im trying to think what this could be. Has the driver been modded at all? I have modified a few TN30s now but can’t remember any having had the symptoms you are describing.
Worst case scenario if you have no luck with someone fixing it and can’t get a replacement driver from thrunite (usually the case in my experience) you can modify the light to not use the magnetic control ring and instead install a piggybacked FET driver and modify the tail switch to act as a simple clicky.
What part of Australia do you live?
Yes mate, all new and charged.
Hi LSX,
Thank you for the help and suggestions.
Hi MRsDNF,
I am on the southern end of the Gold Coast.
Lucky bugger. I’m in Melbourne so its a bit far to drop in with the light.
Damn, I was hoping you would have been on the GC.
If I can not find someone close, I can post it to you for a look if that would be ok with you?
