Hello I have a semi new TC20 v2 that I took apart as I started to get curious if I could dedome the led for slightly more throw. Well I pushed on the dome just a little too hard and ripped it right off the diode! Long story short, I now have an led without the yellow phosphor coating and is now blue.
My question is: Can anyone point me in the right direction of how I can fix this? Do I have to replace the whole pcb or just the diode itself?
Breaking a flashlight myself was what got me into modding too!
From looking at reviews, it seems the LED’s PCB is somewhat non-standard, so you’ll probably want to replace the LED itself.
The basic tools I’d recommend to do this would be:
Solder paste (I use Chip Quik)
Soldering iron
Stove (portable or otherwise) and skillet
Thermal paste
And of course, a new LED - based on my reading, you’ll want to use a 6V version of the LED here.
Convoy sells the XHP 70.2 (https://www.aliexpress.com/item/32850483915.html), but you’ll need to desolder it from the board it comes on.
Then the broad steps you’ll take are:
Desolder the leads on the current PCB
Remove the PCB and clean off any thermal paste on the bottom
Desolder the broken LED from the PCB, and apply solder paste as needed
Place the new LED on the board, squeeze out any excess solder, let it cool
Apply thermal paste on the bottom of the board again
Return the PCB to the flashlight and solder the leads back in place (red is positive, black is negative)
If that seems doable, good luck! If not, I bet someone on the forum would be happy to help you out.
It is not necessary to desolder, just ask Simon to send an unsoldered LED and a separate substrate. I do this all the time.
Well, then, as mentioned above, you will need solder paste, thermal paste, a soldering iron. Instead of a frying pan, I use a regular household iron…
