Hi friend, after years of honored use and realizing that the xml led is starting to get tired, I decided to replace it.
I ask you for some advice on which to use today with the technology advances on the front of the LED chips, I would prefer to keep the same driver and maybe the same base, I can also try a reflow, I have a new heating station for a few days.
i can’t upload photos.
sorry for my english, i am italian.
The best option available for direct swap is a Luminous SST-40. Depending on your exact XML variant, you could see a meaningful bump up in throw and output, especially if a resistor mod is done while you are in there. If you are chasing more throw and care to put in the bit of effort to dedome (or slice) it you’ll have a very relevant performer, all things considered. Swapping out to a different MCPCB can allow the use of Osram ‘white flat’ emitters sometime later if you still want more throw.
