The Thrunite TW20 is a new light in the weapon market focused on simplicity. The TW20 features the SST-70 emitter in cool white, which is rated for 2500 lumens. The beam profile is a large broad hotspot with usable spill thanks to the large LED and deep smooth reflector. Included in the package is a 3100 mah 18650 battery, USB-C cable, spare o-rings, spare charge cover, remote pressure pad, and user manual. The TW20 features onboard charging via USB-C. As compared to the Thrunite TW10 pistol weapon light, you do not have to remove the TW20 from the weapon to charge. The charging port is easily accessible while attached to the weapon.
The TW20 has a spring at the head and a single solid contact in the tail of the light. The remote pressure pad is large and easy to press. The pressure pad is screwed onto the tail of the light. The cable connecting the pressure pad to the tailcap is 9.4 inches long. Unlike other manufacturers, one down side of this weapon light is the light is inoperable as a stand alone flashlight if the pressure pad is removed. The TW20 is mostly smooth but does have some angular pattern around the head of the light. It's quite simple but still a nice looking light. As expected with Thrunite, the anodization is great with no rough or missing spots. As this cannot be used as a stand alone flashlight, no pocket clip or other retention method is included.
The mounting system is the same found on the Thrunite TW10. A thud stud is used to screw and unscrew the light onto the picatinny rail of a firearm. It is a simple and secure method of mounting. There is an indicator light found on the head. Its blue when the battery is above 20% and red when below 20%.
The UI is very simple as it's designed to be a weapon mounted light. The pressure pad can be used for constant on or momentary on. A quick press turns the light onto its single mode. A press and hold allows for momentary use of the single mode. The single mode is rated for 2532 lumens for 140 seconds which will then step down to 855 lumens with a runtime of 84 minutes. As expected the light does get slightly warm at 2500 lumens but as it's designed for weapon mounting, the warmth isn't an issue.
The Thrunite TW20 is a simple and powerful new weapon light.
Things I like:
- Bright 2500 lumens
- Easy to use pressure pad
- On board charging
Things I don’t like:
- The light cannot be used without the pressure pad
- Only one mode (One additional lower mode would be appreciated)
