fwiw
someone recently repaired a sunwayman driver
Time To Mod a TCR-1
Includes the 219b compatible reflector (thanks to research by moderator007), centering ring, mcpcb, listed in post #5
fwiw
Time To Mod a TCR-1
^ Looks great, Jon. I really love this host. Kind of regret never bothering to get one. TCR-1 was on discount for a brief period before vanishing from retail stock, but at that time I still considered it too pricey.
> Looks great
thanks, Im very pleased with the LED
it still is… lol
I would like a do over on the time the V11r went on sale on Ebay for $18. At the time I thought the tailswitch was stupid, so I did not buy any… lol
After I came to my senses… (I thought it was too good to be true, but it was true)… the deal was gone…
fwiw, the V11r reflector is not ideal w 219b… its a better match to the larger LH351d:
pic links to beamshots
Happy to hear again you Moderator and thanks for tried.
My V11R driver work but there is an issues at about 3/4 of rotation it start to flicker,during progression the problem disappears but brightness doesn’t increase anymore.That happen with AA doesn’t have lithium atm. I’ll read your guide,checking driver,contacts and the magnetic ring
for people interested in learning how to mod, here are a few photo turorials of lights I have modded
Sofirn SC21 Pro
reddit tools link, not mine
287 votes and 102 comments so far on Reddit
new list as of 2022
solder iron https://www.amazon.com/UY-CHAN-Programmable-Pocket-size-Soldering/dp/B07G71CKC4/
case https://www.amazon.com/Portable-Soldering-soldering-accessories-Organizer/dp/B07HNXX7X5/
flux https://www.amazon.com/Clean-Tacky-Soldering-Flux-Grams/dp/B07DCD9M3P/
solder paste https://www.amazon.com/gp/product/B0186IM0P0/
silicone mat https://www.amazon.com/Soldering-Resistant-Electronic-Insulation-Station15-9/dp/B075M7PQZX/
thermal paste https://www.amazon.com/gp/product/B0087X728K/
Thermal tape https://www.amazon.com/gp/product/B01MSL64XG/
Kapton tape https://www.amazon.com/gp/product/B00W3FAFP0/
work holder hands free pin vise
Find information about an invaluable tool for watchmakers and jewelers to secure items of various sizes with the hands-free device found at http://handsfreeuniversalworkholder.aspx.
Price: USD 26.99
alternate vise tool
Z-COLOR Mini Flat Clamp Table Jaw Bench Clamp Mini Drill Press Vice Opening Parallel Table Vise DIY Sculpture Craft Carving Tool - - Amazon.com
$10.90
alternate vise with swivel
https://www.harborfreight.com/2-3-4-quarter-inch-articulated-vacuum-vise-3311.html
tool kit Amazon.com
alternate tweezer set
https://www.harborfreight.com/6-pc-fine-point-tweezer-set-93598.html
solder https://www.amazon.com/Kester-83-7145-0415-Electronic-Silver-Diameter/dp/B004DEUYBY/
tip cleaner https://www.amazon.com/Soldering-Iron-Tip-Cleaner-Non-slip/dp/B08SLBSLK4/
UYUE reflow hotplate $50 https://www.aliexpress.com/item/33022471796.html
alternate hotplate, fixed temp 260C $15 https://www.amazon.com/Remover-Heating-Soldering-Welding-Station/dp/B07W1ZZH8T
Jewelers magnifying visor Jewelers Head Headband Magnifier LED Illuminated Visor Magnifying Glasses Loupe | eBay
Digital Multimeter to verify LED polarity https://www.harborfreight.com/7-function-digital-multimeter-63759.html
I buy LEDs from MrAndyZhu WTS/GB: NICHIA 219B NVSL219BT-V1 R9080 EMITTERS! sw45k, sw40, sw35, sw30
when I need to replace an MCPCB, I use this 12mm board MTN XP 12mm Copper MCPCB
and a video about reflowing techniques How to reflow solder an LED emitter on a PCB or MCPCB. Cree XML2, XHP70, XHP50, XPG2, XPG3. - YouTube
gasket for 3535 LED
CREE XP Series 15mm OD Translucent Insulation Gaskets (XP-G2, XP-E2, XP-L)
instead of Kapton tape… recomended by artiet59
kaidomain centering ring http://kaidomain.com/S024680.15_6mm-L-x-9_5mm-W-x-0_9mm-T-White-Plastic-Insulation-Gaskets-for-Cree-XP-L-5-pcs
Hi guys which newer RRT01 driver should I order from Jetbeam for the replacement? It is good to buy some spares in case they discontinued the production of RRT01. I got the 2011 version. Thanks!
I prefer the 2011 and 2012 original drivers. they are less likely to flicker visibly at sublumen outputs. The 2012 version added strobe.
2011 and 2012 drivers cannot be purchased anymore.
you can buy as a backup, either
2019 driver, it has higher output, but can flicker visibly at sublumen levels
or
2020 driver, it has same higher output, plus thermal step down, it can also flicker visibly at sublumen levels
Is the sub lumen flicker a known bug? Is it found on all the newer models?
it is not documented anywhere, just my own observation of a few of my lights, and confirmed by a friend who owns about 5 RRT-01, that he upgraded to 2020 drivers…
you be the judge, if you cant see it, I would not worry
2011 and 2012 drivers cannot be purchased anymore.you can buy as a backup, either
or
Noted with thanks!
Luck of the draw. My 2012 RRT01 flickers on sub-lumen output, both my EYE10 and 2019 RRT01 don’t. All three have been serviced, i.e. taken apart completely, got new LEDs and silicon grease.
The flicker/pulsing is really strange. I estimate its frequency at about 20 Hz, but what generates 20 Hz? Or is it beating, i.e. two clocks being slightly different?
Modded a 2012 RRT01 today. Cree XPP 3000k 90cri, with a Kaidoman “18mm x 12mm” 5mm opening reflector. Only reason that is in quotations is because Ive ordered multiple 18x12-ish sized reflectors over the last couple of months and this one isn’t exactly the size of any of the reflectors listed on Kaidoman. I’ve included pics of the reflector measurements. I had to triple stack Convoy 16mm mcpcb’s (3535 size) to compensate for the height difference between the stock reflector and this new one. It worked out well as it brought the lip of the reflector right to the edge of the head so the bezel now closes all the way with the stock lens installed. I did not use a centering ring as the XPP in this small reflector focuses really well without one. I just installed kapton tape to cover the leads (and ended up covering the entire mcpcb with Kapton Tape).
Overall Im really happy with the mod. I always take the opportunity to use an XPP when I’m not worried about overdriving it. I had an SFT40 3000k in this yesterday with the stock reflector but there was a pronounced ring around the hotspot i couldn’t get rid of. Im pretty sure its bc of the design of the stock reflector. This setup will likely remain as its a pleasing beam and tint, and hi cri.
I have an RRT01 on the way. If I decide to try the grease in order to firm up the ring rotation, does it just come off after unscrewing the head, or is the dis-assembly more involved?
no, yes, however
The 2020 RRT-01 has a lubrication hole in the control ring. No disassembly required. Just squeeze a bit of Nyogel 767a into the hole.
I picked up a Nite Eye Eye10 last night. Waiting for it to come in now. Pretty excited to see how it compares. Really enjoying these old rotaries, the rrt01 has been in the pocket for a couple days now. Wonder which led I should do on the eye10.
Awesome! congrats
Domed 519a makes a nice Phat Hotspot w stock reflector, and Lots of high CRI Lumens
if you dedome, or use smaller LEDs, the kaidomain reflector (Reflector #2 in post #5) helps get rid of the shadow ring in the spill
Awesome, thanks Jon. I forgot to ask the seller if that Eye10 comes with xml2 or 3535 emitter? I notice in the photo it has a OP reflector, which would be great if it came with 5050 bc then sft40 would also work well. the “2012” smo reflector does not like sft40, too many rings. Problem is finding a reflector in that size thats also 5050 capable, and OP.
yes, same mcpcb as your 2011 RRT-01 (that comes w XM-L and smooth reflector)
I would try the kaidomain reflector #1 in post #5 (buy and try both #1 that has a 5mm base opening, and #2 that has a 6mm base hole). I believe they will both clear the 5050 light emitting surface (With the centering ring in post #5), but the smaller opening in #1 will probably work better w LEDs w a small emitting surface (no experience w SFT-40, please share what you learn).
Great little light. Grats on your Eye10.
Internally, it is pretty much identical to the early model RRT-01. The same driver. XML-2 emitter. Mine had an OP reflector which looked much better than the RRT-01 and TCR-01’s very ringy smooth reflectors.
All body components (bezel, lens, head sections, tailcap and clip) are interchangeable with the early model RRT-01.
Main noticeable differences are the body styling. And that moving the ring feels and sounds like opening or closing a zipper. This is due to the ring having detentes for the ball bearing over its entire course of travel, not just at the ends like with the RRT-01.
My imagination or is that a ten year old light. Love the design. Had to look that one up.
