I’m not weird… Honestly, I’m not. :cowboy_hat_face:
Have some lights here in various form and after reading the posts I was curious of the how or why shadows were blurry or crisp edges.
I always want to know why.
Also the light I have at the moment without lens or reflector is using a Cree XP-L HI emitter.
You are trying to accomplish what I would not necessarily want from a flashlight. Too white causes reflection back in your eyes and washes out the color. Also harsh shadows make it hard to see more. Warmer colored light or what we call high CRI emitters will offer better visual effects to bright flashlights by blending the shadows and reducing reflection back at you. The Sun in your pocket.
So Lexel… I’ve just looked in to dedoming and read that there can be a serious impact on lifespan, which might be a big problem. I think that the xpl Hi might be the best compromise.
I’ll start looking for someone local who can build what I need unless anyone on the forum feels like taking on the job?
You could make changes like replacing the battery with a set of wires, or using the threads at the front to mount it. I think it’s an excellent beginning to your art project.
Cheers Joshk. I suppose that could be the quick fix if, as mentioned above, I can saw the back off, fill it with glue and connect the right power to it.
Could I run in to problems with it cycling through the different modes when powered on/off?
I suspect that the length of the torch would be too much for this situation. The led would most likely be way too close to the metal design to cast sufficient shadows.
I agree with djozz, the Osram Black Flat “kills” all the other LEDs in this regard. 700 Lumen from a 1mm^2 DIE and it also produces a “crisp” coll-white tint which should add to the effect.
Good heatsinking is a must though at these currents!
I guess my photo editing skills are slow. So just use the head then. You can use any switch to toggle the modes. And it has mode memory, so it should stay put between power cycles.
That or the XPL - HI seem like 2 pretty good options to look in to. 700 lumen from such a small size sounds phenomenal.
When this thing is made on has good heatsinking, is there anything that you think might cause problems if I put it into an IP67 enclosure? Could it overheat and cause me problems?
I would go away from flashlight and build the star on a heatsink and seal the solder joints with acryl or epoxy, then it is IP68, no need to add a case with AR glass and heat problems.
Pretty much the star mounted on a heatsink,
cables to the PSU and buck driver that are in a case.
It is easy to get 700-1000 lumens from a XPL HI on DTP star.
XPL HI V3-3C on noctigon DTP Star
28mm AR coated glass
5m cable for conection LED to power box
small heatsings for buck regulator
arctic silver ceramique 2 heatpaste
first tests with the buck converter
to get the brightness adjustment realized
