Yea dx is probably one of the older sites. I bought a screw driver bit set from them in like 2012.
It’s actually good quality still going now. They are fairly active on social media.
Got mine in a few days ago too, and got my TIKI last night. The Tiki has a much nicer tint and is so much lighter. Coming from a TINI, I find it weird that the TIP2 takes just as long to turn off as it does to turn on…
Wow, you mean Nitecore sometimes uses tints other than cold white?
Yeah, i bet it’s much lighter, since it’s all plastic except the bezel.
I wonder though, where the heat is supposed to go to, but i don’t know how bright it is on max.
But if the PWM was not visible, i’d probably buy one.
Hmmm…
Mine turns OFF with a short click.
So i tried what happens when you press the button a long time, and then it indeed turns OFF with a similar delay as turning ON.
This is indeed different with the TINI, but the TINI also turns off with a short click.
By the way, those tail magnets are really strong !
It takes quite a bit of force to detach the tail cover.
