Mine does it only when I release the button each time the color changes.So, after rainbow, clicking 7H(and release button after color change) it goes blue, next 7H(and release button after color change) again blue.Next 7H it goes red!
When I keep holding the button, everything works fine(colors—>rainbow—>fast cycle=voltage check—>red again=begin of color cycle)
No big deal to me, it’s a nice flashlight to play with…Great work toykeeper!
I haven’t attempted to calibrate the temp sensors on mine or change the temp settings yet. I turned them on turbo and verified that output seemed to be ramping down in good order though.
Some additional impressions now that I’ve had my D4v2s for a day:
Both the battery tube and tailcap are interchangeable with equivalent parts from later model D4v1s. Also the grey anodizing on the v1 and v2 is close enough in color that if you swap tailcaps the v1’s tailcap looks like it was made for the v2.
I like the v1’s tailcap better than the v2. The v2’s tailcap is longer and heavier to make room for lanyard ring. This probably adds 2-3mm to the length of the tailcap. It’s a great feature to have … if you actually use a lanyard. But if you’re like me and do not, the lighter more compact v1’s tailcap feels better in the hand and pocket.
The knurling on the 18650 body tube is excellent. Very grippy. The light feels much more secure in the hand than the v1’s smooth body tube.
The SST-20s are pretty greenish. About as green as the tint in my D4v1 SST20 and much greener than the ones that came with my SST-20 FW3A. However, I am using a UCL lens in my FW3A and the stock lens in the D4v2. I haven’t checked, but it is possible replacing the lens in the v2 might help.
Stainless steel bezel looks good. Build quality is excellent with no defects noted in either light.
Tint on XPL HI 4000K D4v2 is much rosier than the tint on my SST-20 4000K version in all brightness modes. As expected, the XPL HI version is also considerably brighter.
D4v2 SST-20 2x 3000K & 2x 4000K w/ Carclo 10623 frosted optic and no lens at 1st blink
lumens at 1s: 81
CCT: 3367
DUV: 0.0003
CRI: 98.3
R9: 97.8
Rf: 93
Rg: 100
D4v2 SST-20 2x 3000K & 2x 4000K w/ no optic and no lens at 1st blink
lumens at 1s: too floody to measure
CCT: 3614
DUV: –0.0052
CRI: 97.2
R9: 95.0
Rf: 93
Rg: 102
Seems like Emisar uses the same glass as the UCL lens. I tested all of Emisar lights to see negligible DUV differences between w/ glass and w/o glass. The light gets super hot much faster than the two FW3A SST-20 4000K I have. I really like this light and I think it would have been perfect if it had 8x7135 like the FW3A instead of 1x7135.
On turbo, the mixed tint appears very rosy, similar to my E21A Tiara Pro with 2x3000K and 2x4000K, but at similar outputs the E21A Tiara is noticeably rosier. Overall I really like this light and emitter configuration.
I can’t tell if the SST-20 4000K is the FD2 or FB4 tint bin since I can’t measure it without the 3000K. However, setting it to similar low output levels and comparing the emitter color with the FW3A, they look near identical. I hope someone can measure the SST-20 4000K to confirm which bin it is.
It’s not the ideal material, but that doesn’t mean it isn’t a serviceable material if you have other priorities than maximizing the sustainable output level.
Even if it wasn’t an amazingly high output light for its size, I’d still rate the D4 as well worth its price.
I think I’d really enjoy a warm white D4v2 titanium for around the house use, while for working in the yard, on my car, etc, I will continue using my aluminum D4.
Seems like very few ordered the Nichia option. My impressions of the Nichia 219CT are positive. There is an ever so slight green tint - but it's really subtle. When I first pointed the light at the ceiling, I thought I had gotten a pretty white output. Only when compared to my snow-white reference light (Nitecore TIP), could I see it. But it's not something you would notice, without really looking for it.
My D4v2 does not have yellow and white aux lights. Is that standard or is mine not working correctly because Emisar’s website says aux lights are R, Y, G, C, B, V, W, Rainbow
Try setting the AUX output to high and then click through the different color choices. I noticed with mine, set to low output, the yellow doesn’t come through all that clearly, but when set to high, I see it.
I don’t really see clear/white on either output level, when it auto scrolls through the colors, but yellow is definitely there on high AUX output.
Contrary to other lights with aux leds we’ve seen so far, the D4V2 has RGB aux leds rather then monochrome leds. The different colors are obtained by turning on and off the R, G or B components of each RGB led. That’s 8 combinations - including black (all off) and white (all on). Note that without some sort of calibration, the white is rarely pure. It is often tinted one way or another.
