Got distracted for a couple days… sorry for the long post:
If you want, you can just disable thermal regulation entirely. I don’t recommend it, but you can. The guys at Illumn did it once for testing purposes, and they managed to melt the optic.
So if that’s a thing which appeals to you, get the light hot then go into thermal config mode. Set the calibration to 1 click, and set the limit to 40 clicks. This should effectively disable thermal regulation, by raising the temperature limit to like 100 C or hotter.
Again though, I don’t recommend this. It can easily cause burns or damage.
I’ve never actually seen a SST-20 6500K. I don’t have a good answer.
I hope so. I sent Hank new firmware twice since the D4 V2 was released, including just yesterday.
The default ramp settings are in the first post of this thread, and the default temperature limit is 45 C.
Occasionally some of the changes aren’t improvements though. I found a brand new bug yesterday. More on that in another post though.
Yes. Muggle mode uses the same temperature limit as the regular mode.
Nope. At least, not without modifying the firmware. That’s the power-on self test (POST), which confirms that power is connected and main LEDs work.
Yeah, the idea is that you should hold the button until it gets to the color you want, and then let go.
… having a bad day?
Indeed. There can be pretty significant differences in tint and lumens, and it’s totally random.
:+1: on this too. Different people are different. And that’s okay.
It’s hard for me to not see green tints as green, regardless of what the light is shining at. My eyes don’t adapt to it. They seem to have one setting, and that setting is below the BBL.
I would if I could, BabyDoc.
3A and 3D have the same amount of rosy tint, but different color temperatures.
