Perhaps you could talk TK into writing it to suit you for you. She’s pretty busy though and at this time it’d probably be asking a lot. Quite a few people make their desired changes to the code and re-build it then flash that to their light, this can be done in the AVRStudio but I quit doing that myself back when Anduril got started. I could tell easy enough what to do back in Bistro and A6, but Anduril is too complex in the code for this ol boy.
What kind of equipment would I need to flash to a new firmware version? My D4V2 is in the mail and I’d like to flash it to the latest version that includes the safety rampdown feature (when it is available). Is there a guide for flashing firmware?
Well, at least one thing that I know of that you'll need it's the Re-flashing Kit for the D4V2 that Hank now has for sale, on the same store where you've probably ordered the light itself. As far as where you'll get the firmware itself I've no clue yet, as I haven't got the flashing kit in the first place, thus I haven't looked any info on that so far.
TK, that would be a great addition. Would the long hold be able to unlock it as well. I find that I screw up the 4 click sequence about as often as I get it right.
Lower muggle mode ceiling is definitely possible. It’s just difficult to get manufacturers to accept the idea of making less light.
TBH though, I’ve also been wanting to remove muggle mode entirely. And if I add basically anything else to the firmware, it won’t fit on every supported light any more, and then it’ll be necessary to remove something. If that happens, muggle mode will probably be the first to go.
I don’t think it’s a good idea to use hold for unlock. The whole point of lockout mode is that it can’t be unlocked by accident while the light is in a bag or a pocket, so allowing a hold to unlock it would make the mode stop serving its purpose. Would also interfere with its use as a momentary low mode.
The initial ramp-down should probably happen pretty quickly, since it takes less than 10 seconds to start a fire on some lights. I set the timer at 5 seconds because it takes about 2.5s to ramp all the way up, and then 2.5s more to start ramping down, which is plenty long to let go of the button but also usually fast enough to avoid fires.
The main thing I’m concerned about is how it’ll interact with long stepped ramps. It counts the duration the button has been held, not the duration it has been at the ceiling. So with a long enough stepped ramp, starting from the floor, it turns around immediately when it hits the top, then locks immediately at the bottom. But with the smooth ramp or with just 7 levels, it stays at the top for a few seconds before ramping down. And if it bounces off the top with a long ramp, it’s simple enough to let go and hold again to go back up.
That's not good. "Safety features" should not get in the way of normal use.
I'd rather have no autolock/autorampdown at all than something that might suddenly interfere with my inputs. This is an "enthusiast flashlight (UI)" after all. ;)
I guess I wanted to say move the "Beacon" mode to the Strobe groups, but came out whatever came out. Happens when I'm trying to do more things at once and then I forget what I was doing and resume.. :))
Also what I mostly like on a Beacon signal is how short and intense the flash is, something like the flash on a camera blitz, or one flash from a strobe mode - But noticed this isn't the same here with the "Beacon" mode in the Blinkies Group. This one "looks" more like a "slow flash" at "x" time interval. Myself, as an example I like the Beacon modes as on the Manker, or Nitecore Lights - a very short and bright flash at around 2s intervals.
I wouldn't cry after the Muggle Mode personally, so if it ever gets removed entirely, that's no loss for me :)
Why counting the button hold from start and not from context (e.g. ramp ceil) ?
Agreed. Having 20 ramp steps and ramping up through all of them in a single hold isn’t exactly common though. And if it happens, it’s really easy to let go and hold again for a moment to get back up to the top. I’m not very worried about it.
I usually prefer a short sharp beacon too, instead of a slower gentler one. I tried to use what I saw in other lights though, which was pretty slow. It was 500ms on, and then N.5 seconds off where N is configurable. Since then though, I got annoyed enough at it to speed it up. It’s now 100ms on and N.9 seconds off. So it’s a lot closer… but still not the ~5ms ontime I’d normally use.
Mostly to use less ROM space and less RAM. There’s basically no room left, so I made it as small as possible. A counter already tracks the duration of each hold, so I used that instead of making a new one.
Probably her elaborate safety on the side switch when in lockout… or anytime I guess… a prolonged press of the switch will step it all the way down to moon and keep it there. So if the switch gets pressed in a bag or in a pocket it can’t stay on a high power level.
Only guessing, but that’s probably the new revision.
