TLC5940
Has anyone used the Texas Instruments TLC5940 or any of it’s cousins for driving LEDs?
I noticed this link referring to high power LED usage, and paralleling the outputs:
http://www.ti.com/lit/an/slva253/slva253.pdf
Looks like the TLC5940 is capable of up to 1.92A per chip, and it supports 64 step analog dimming per channel. If all 16 channels are driven in parallel to one LED, that means you could have 1024 step analog dimming! To top it all off, if that weren’t enough it even does PWM.
Is this the easy solution I’ve been looking for?
@ChiggerPepi
Sure I’ve played with the tlc59401, which is the same except the dot correction has to be read in at startup each time.
I wouldn’t say these chips are easy. Using an linear AMC7135’s, or a Zetex inductor based solution would be easy.
Yeah, reading in the dot correction is no problem, but the grayscale clock and PWM needs to be set up too, and is a bit more work. This involves a hardware PWM to feed an external input to a Timer (TOCK pin in PIC terms), and then a timer interrupt routine to Blank the PWM period after the Timer overflows. Lots of housekeeping to do when you have 16 inputs to deal with.
I’d have to think that whatever package you anticipate using would be smoking hot at approx. 2A.
If you do proceed to use the chip it would be interesting to hear your results. Good luck.
