+1
The spacing on those vias is 1/10ā so you can solder in a 2-pin header and use a plug from the backside. I think thatās better for series LEDs that use 1/3 the current.
Good question, if we made quads, should we do 24mm to suit Carclo 106xx series optics or 32mm to Ledil Cute 4?
Cheers
Mark
holes will suit 20AWG, 18 at a pinch with some trim
Yes hole pitch designed to suit .1'' (2.54mm) headers
Cheers
Mark
Why did I know you were going to say that
Thanks for considering it even that is very good news.
I am mostly interested in the 32mm for the CUTE-4, because with XP-Lās those who have tested those limited run i think russian made 24mm DTP quads with the carlco optics, have showed about the same lumens as the 32mm CUTE-3 triple. But the CUTE-4 quad should be an improvement.
But still for other ledās the 24mm DTP quad would be interesting, so i agree why not both there is already demand for it and a market for both, i am pretty sure i could have a use for both
Can you do a Luxeon Rebel triple? Cajampa and I have been kicking around the need for a 20mm parallel triple Rebel for a while.
yes we have a 20mm triple with Rebel/Cree
would just need to make a TPAD version of it
> use the vias and jumpers for parallel ā¦
Can you show a picture of how that wiring and jumper setup for parallel looks?
Thatās doable with the 20mm Rebel triple currently available?
The current PCB is 2 resistors that create a series config, you would need to wire external for parallel
The top board is current, the lower one is a new 20mm TPAD, but we have yet to order any yet, but we would need to mod to again take Rebels
Cheers
Mark
Thanks, I doubt thereās a market for making parallel rebel boards or someone would have done it.
KD has premade parallel boards with Nichias and a variety of different XPL-HIs as well, but not for Rebels
Iām going to try the twisted-teflon-wire method shown in A Day of Fails and Other Fun with Osram Oslon SSL 4000K 92CRI Emitters. Day Two: Fail becomes a Win. New emitters and a new tint for wiring
These arenāt copper!
If you want to use them for 3amps in total they might be ok , but use only noctigon/tpad copper boards if you have the ability to buy .
There is no problem in fact that they are non-copper.
Even it is not big problem that they are non-DTP.
The biggest problem is that they (as 99% other chinese boards) have very bad design with small width and thickness copper layer and whole copper area.
