Hello,everyone,
I am Rayus brand dealer and our new model RAYUS A10 is released ,Here is the pictures for your reference.
RAYUS A10 is a multicolor tactical flashlight, firm and reliable, with high performance and advanced constant-output.
with multi-color, the light can be applied in more environments and industries, especially the bad outdoor environment.
3 tints, 4 output levels and 4 flashing modes can be controlled easily by the side switch, which is very convenient for user.
There is hidden power-indication to detect the remaining power anytime, the flashlight is compatible with18650 battery, 16340 battery and CR123A battery. Due to moderate size and weight, waterproof function to IPX-8, A10 is the wonderful lighting tool for hunting, fishing, searching, rescuing, etc
Four tints, four combinations
High performance, widely used
A10 WRB:white, red, blue
A10 WGB:White, green, blue
A10 WRG:White, red, green
A10 RGB:red, green, blue
Four tints’ parameter
White: use Cree XP-L (V5) LED 10W output power
Blue: use Cree XT-E (Q) blue LED, 5W output power
Red: use Cree XP-E (P3) red LED, 3W output power
Green: use Cree XP-E (R2) green LED, 3W output power
The application of red light
Red light’s wavelength is longer, not easy to reflect, so people always use it to view objects in the hunting and military environment,
and it’s not easily found by animals and others. Red light’s influence on people's eyes is smallest, can reduce the visual fatigue in the dark.
the red light can replace white light to be used for search, snow environment, it can reduce the reflection greatly and enhance the visual identification.
Green is the light human eye is most sensitive to, so it is widely used in hunting, search and military, etc
Using the green light people most sensitive to replace white light for Strobe, can cause people instant vertigo,
and be good for self-defense. At the crucial moment, it can give warning and reminder.
New digitally regulated circuit with high efficiency and stability, maintains constant brightness
Hidden power-indication to detect the remaining power anytime
Low-voltage warning function to remind users of low power
Intelligent temperature protection function to avoid overheating
Intelligent memory function to remember the last output level used
Three tints, 4 output levels, quick access to Strobe, hidden SOS
Hidden power-indication to detect the remaining power anytime(just for 18650 Li-ion battery)
Double-click the side button quickly while light is in low output level for any tint, the flicker times will show the relevant power.
Light flickers one time to show the remaining power is less than 25%.
Light flickers twice to show the remaining power is less than 50%.
Light flickers three times to show the remaining power is less than 75%.
Light flickers four times to show the remaining power is highly enough
If the light works on Turbo, when the temperature goes up to a certain critical point,
the light will enter high output level automatically to avoid overheating.
4 tints, 4 combinations, multiple colors for wide usage
Blue: use Cree XT-E (Q) royalblue LED
143mm(length)x25.4mm(diameter)x45.0mm(head)
Weight 167g(excluding battery)
IPX-8 (waterproof up to 2 meters)
Max 270h runtime(powered by 3400mAh 18650 battery
Max range 236m
quick access to white Strobe or green strobe
High-accuracy metal smooth reflector, beam is perfect
Toughened ultra-clear mineral glass lens with double-sided anti-reflective coating and high optical efficiency, anti-scratch and shock-resistant
The reliable stainless steel side button is to select output levels
Tactical switch in tail, press it to turn on the light quickly
Reverse polarity protection to prevent damage resulted from improper battery installation
Powered by 1*18650 battery or 2*3V CR123A batteries
shock-resistant inner body design ensures the reliability and safety in the strong shock environment.
Made of durable aircraft-grade aluminum, premium Type III hard-anodized anti-abrasive finish
Easy to operate even when user wears gloves
3 tints, 4 output levels, quick access to Strobe, hidden SOS
Press the side button for 2 seconds to enter the Strobe while the light is turned on.
Any question please send PM to me ,Thank you!
