MC18 is a perfect magnetic USB charge EDC flashlight and headlamp for dual-use, it has 5 working modes: High>Middle>Low>Moonlight>Strobe. Powered by 1*18650 or 2*CR123A. it’s use MVB BEAM, intelligent circuit build inside,constant current,constant brightness. with a faster 5V 2A magnetic charging cable and it could charge directly with power bank, computer etc. you can charge it conveniently. Free your hands and increase exploration of the outdoor experience.
The Link:https://ebay.to/2UFzkuG
https://www.ebay.com/itm/194164457505
MC12 1000 Lumens Multi-function LED Flashlight LED Headlamp.it is a beauty,tiny high performance magnetic rechargeable headlamp & flashlight.Max output 1000 lumens has high operability and high reliability. With intelligent temperature control system and low voltage warning indicator.magnetic USB charge EDC flashlight and headlamp for dual-use, intelligent circuit build inside,constant current,constant brightness. with a faster 5V 2A magnetic charging cable and it could charge directly with power bank, computer etc. you can charge it conveniently.
MC12 powered by 1*16340 battery(included) and using magnetic charging technology. On the top with one-click mode switch button and magnet function at the Tail, IP68 anti-dust waterproof rating and 1 meter drop test which is a great choice for home use and outdoor use.
MC12 has 5 WORKING MODES — High (1000 lumen, range 105 meters )>Middle (200 lumens)>Low (60 lumens)>Moonlight(3 lumens)>Strobe(1000 lumens ). Along with a low-voltage indicator underneath.
The Link:https://ebay.to/3kRnus2
https://www.ebay.com/itm/193712946823
H5R is a high-brightness, lightweight dual light source rechargeable headlamp. It has five modes in total(four modes for normal use and one strobe mode). IIt Use two international patented LED, up to 50000 hours lifetime.150 degrees large flood light design. Max 600 lumens. Four light modes are perfect for hiking, camping, mountaineering and other complex outdoor environment. Micro USB charging and power detection provide you with good charging experience. Long battery life. Single button control which is easy to use. It has a reflective sweat headband and it is comfortable to wear. IP68 level dust and water resistance. H5R will be lightweight and practical interpretation of the best.
The Link:TrustFire Mini Led Stirnlampe USB Wiederaufladbar Kopflampe Wasserdicht Schwarz | eBay
EXTRA 5% OFF WITH CODE :TFEBAY50
eBay TrustFire US store: | eBay(link is external)
eBay TrustFire DE store: | eBay(link is external)
eBay TrustFire UK store: | eBay(link is external)
Amazon Manchest US store: https://amzn.to/3kNiAfX
