I was in discussion with another person whether a TR-J12 host weighing 1.2kg (Gearbest lists this as 1192g product weight, 1.5kg package weight) would be able to sustain 10k+ range lumens output for 30 mins (XHP 70.2, whatever), or when the batteries run out. I don’t have a TR-J20 to test and verify, but i do have a X100.
Trustfire X100 7 x XM-L T6
Weight with battery tube (no batteries) : 589g as measured. Websites list this as 940g, which should be the whole package weight with sling and bag
Size(mm):342 x 75(bezel)/35(body)
Not sure if the result is useful to anyone.
The light tested below is direct driven by varying the voltage from a PSU, trying to aim for 3.5A, the amperage always tries to slowly creep up during the run as the temperature rises.
78 watts power. No driver loss etc as it’s direct driven.
Also, for the first 7 minutes a small fan was aimed directly at it to simulate windy conditions in the real world. If it’s nearly calm, the results would be worse, of course.
Results
30.9 deg C at 0:00
55.3 deg C at 3 min
62.9 deg C at 5 min
67.5 deg C at 7 min (battery tube temperature = 49-52 deg C at the part where you’d grab it).
First an underexposed beam shot pic vs the BLF Q8 in Turbo with springs bypassed but “only” on Panasonic 18650GA
30.9 deg C at 0:00
55.3 deg C at 3 min
62.9 deg C at 5 min
67.5 deg C at 7 min
I took away the fan and see if it could hit 80 deg C. Yes, no problem at all. The current crept up also till 3.80A when i stopped varying the voltage to compensate. Got 182 deg C at the front end too (LEDs and aluminum light cup mix)
I terminated the test, didn’t want to push till 90-100 deg C.
