While this does generate less heat (and output too) due to it’s rather conservative 7 amps, we can’t say for sure if it will run on high for long periods of time (unless someone has actually tested the driver in an X6). Personally, I’d just keep looking for a 9-10 amp driver that doesn’t kick down so early.
I mean, if we’re going to go through so much trouble to make a beast of a light, why not do it well and make it last a long time?
There is a new 9 amp driver here that I know nothing about if thats any help. http://www.intl-outdoor.com/9a-3mode-5512v-circuit-board-p-561.html
anyone have a good place to but an X6? Heck, a dead or empty X6 would be better but unlikely
MF are showing it but before I paid for anything I would check with there live chat to ask if it was available for immediate shipping to prevent disapointment. http://www.manafont.com/product_info.php/trustfire-x6-sst90-led-2300lumen-5mode-led-flashlight-shoulder-strap-318650-p-5632
Edit. I just read this on the other thread running. http://www.aliexpress.com/store/product/Zero-Profit-Trustfire-X6-high-power-LED-tactical-Flashlight-5-Mode-2300-Lumens-SST-90-LED/610867_627623140.html
They look like the exact same driver to me :~
Anybody know of another cheap 9A 3-mode driver?
If you read the specs the KD driver for a start is single mode whilst the IOS is 3 mode. Good luck on your mission.
I think we are talking about to different drivers. I’m referring to this KD driver: http://kaidomain.com/product/details.S020148
The specs looks very similar/identical to this one: http://www.intl-outdoor.com/9a-3mode-5512v-circuit-board-p-561.html
Sorry if I misunderstood you
Lothar. Yes your right. There is another link above to a single mode driver at KD. Cheers.
I think they are the same driver, my speculation is that they were all made by FlyDragon, regardless of 1 or 3 modes,
The modes is on the 2nd chip that doesn’t over heat, regardless of 1 or 3 mode version, the same problem exist with over heating thermo step down.
The thermo step-down is not fail proof, I had one burned out despite the step-down, best is to heat sink it well to avoid the step-down. Both drivers will need to pot the back side of the big IC board to a heat sink that’s touching the flashlight body, there is no short cuts. I did it by flipping the big chip & make the bottom surface facing out side for potting to heat sink with as little gap as possible. (Potting a 1/4 inch gap does not help much).
Just a comment regarding to swapping to 7A driver, the stock driver Hi is 6.5 Amp, so there’s little to gain.
Another thing to watch for ! Voltage
I know it said 5 to 15v , but sometimes they just cant handle both - current and voltage …
To get it to run on high without throttling back you may need to back of the voltage to 2 x 18650 [ 8.4v ] , …
I had the same problem years ago when modding Mag-lights , the driver simply refused to run @ 12v , but once the voltage was backed of to 8.4 , seemed to run fine .
I think you got it. It just ran for 5 minutes without stepping down. Sadly the tube does not work with 2 18650s but it would work with 2 18500s. :(
Now where do we get those 18650 spacers/dummy cells…
Just make one, that is what I'm working on right now. :D
I don’t have any plastic tubes the size of an 18650 though… maybe a foil cylinder wrapped like a normal cell in electric tape? o.o
I'm just using a piece of aluminium rod wrapped in electrical tape.
still waiting on beam shots
Beamshots already posted ;)
Thanks to Brad finding me a camera, I can now post some beamshots. :D The distance is 350 yards, only my best throwers were actually visible at this distance. I had: a 11 amp X6, a Fatmax XM-L spotlight, a HD2010, a STL-V2, a 5 inch reflectored incan, and a small XP-C spotlight. The HD2010 and the STL-V2 weren't able to light it up in any significant way, so this is only 4 lights; all of which do a good bit over 50 kcd. For everyone doubting the distance, I had it zoomed in all the way. X6:…
hello,I would like to mouth the driver 9A KD 26mm on my x6 …how do you fix it?? then it work wellperformance?heats thanks
