I think you will find the Trustfire X9 is too large, it is only 40mm shorter (198mm total length) then the STL-V2/V6 (~240mm). Considering the STL-V2/V6s have 65mm's more space in the battery tube you may be better off looking for something shorter yet.
My Trustfire X9 arrived today! First impressions are very good, one thing I have noticed however is that it is well focused at about 2m but beyond that a hole starts to appear in the center of the hotspot. The further away it is aimed the worse it gets. Max I have been able to experience this is at about 7m (indoors) as it is too bright outside. I have found that if I unscrew the driver and emitter module a small amount it fixes it (however the hotspot is very slightly larger because of it). Just from a quick comparison of only the hotspot of the beam it appears about twice as bright as my p60 R5 drop-in (textured reflector) and slightly smaller (R5 at 1A). Outside at night this difference will probably shrink noticeably, but I have a KD 2.8A driver on hand waiting to be re-homed.
The white plastic spacer between LED star and reflector may have been mounted upside down. If correct, it should fit (engage with) the reflector bottom and its hole.
Yes it does thanks. I just tried turning it around (it is the correct way up already) and this fixes the problem somewhat however only because when the wrong way round it is thicker as it does not slot into the reflector. From some pictures off here it would appear my light has a smaller isolating ring then others. It also has thicker side walls below the LED board then what is pictured on Manafont and DX (much like the picture in Old4570's review).
My Trustfire X9 was purchased from DX ($44.40) and included 2x Trustfire "2500mAh" (blue) 18650s. They look unprotected to me.
