My guess is there might be a tiny visible gap.
The EDC05 clip seems nice, but it’s not long enough. It lands just short of where it should, which makes it harder to clip onto things.
I like the S-Mini clip quite a bit too, but I don’t have any extras to use on other lights, and it seems like it’d probably be a bit too short.
The ZL H52 clip is my favorite so far. One of mine lands a millimeter or two past where I’d like, so I pull it slightly away from the light while unscrewing the head. My other H52 clip lands precisely on the right place though, giving it optimal clip-on, optimal retention, and no contact with the head.
Wurkkos’s latest TS10 headlamp design shows a H52-like clip in the rendered image, so I’m hoping they’ll follow through on that.
Since the button is on the head though, I’d prefer to flip the clip around. I generally want the button oriented upward while clipped onto things, so I can unclip and have my fingers already in the right place to turn it on without flipping the light around.
it fits, but is not low profile: (and I dont know if they are available for purchase anymore)
good find! that looks like a very promising low profile clip option (even though it rides on the head):
it looks like there is a charging port cover on the head? The button might still be on the tail?
If I understand correctly, the button is under the charge port cover. So the user would press on the cover to click the button, or take the cover off for charging. It seems like a strange design.
thanks for the insight
yes, that sounds like something a non flashlight user would design… ![]()
That clip looks very close to the H52 clips Very Nice!
So very true. We will have to see how it is implemented. But I do like the clip… if the production model has the same one, it could be a good option for the TS10… AND maybe available.
EDIT:
So maybe common sense will prevail…
Is there a suitable brass or copper clip available that will fit the TS10?
I have the brass TS10 but don’t like the included clip.
@jon_slider do you have any recommendations? Not sure brass or copper clips even exist at this point?
I think the Baton 3 clip works (maybe someone will confirm), though I have not tried it myself… there is a Rose Gold you might like
I meant to buy a baton three clip, but I accidentally bought a baton three pro clip. It worked out well though. It’s too big to fit over the groove, but it snaps perfectly over the tail cap. And is now deep carry it fits flush in the pocket.
