Connecting to SerialUPDI
Pinging device…
Ping response: 1E9421
Writing from binary file…
pymcuprog.deviceinfo.deviceinfo - ERROR - Memory type ‘all’ not defined for device ‘attiny1616’
pymcuprog.deviceinfo.deviceinfo - ERROR - Memory types defined: eeprom, flash, fuses, internal_sram, lockbits, signatures, user_row
pymcuprog.pymcuprog_main - ERROR - Operation failed with ValueError: Memory type ‘all’ not defined for device ‘attiny1616’
I chatted with carsknivesbeer about this through PM. In case anyone else runs across this… when downloading the hex file, it accidentally got a “.txt” tacked onto the filename which confused pymcuprog. Removing the extraneous extension resolved the issue. Easy enough problem to run into, and something to watch out for.
And make sure you change the actual file name instead of just the shortcut (especially if that’s the second thing you thought to change if only you did it right the first time…).
Just wanted to let ppl know that Terry has been very helpful and the problem should be solved now. If all goes well, a ‘replacement’ should be on its way soon.
I like the neutral tint. Judging from skin tone (shining lights on my palm), I think it has good R9. Low R9 lights tend to show very pale skin tone, but TS10 produces good skin tone. However, TS10 seems to produce less reddish tone than E21A. So I guess it has less R9 than Nichia E21A R9080.
CIE x,y values, CCT and calculated DUV are as follows:
(CIE x, y and CCT are measured from Opple Light Master)
At about 10 lumen: x=.3332, y=.3366, CCT=5466K, DUV=–0.0026
At about 100 lumen: x=.3320, y=.3360, CCT=5521K, DUV=–0.0024
Here are some comparison beam shots.
Wurkkos TS10 (L) vs MT06MD 219B 5000K ®
Wurkkos TS10 (L) vs KR4 E21A 5000K R9080 ®
Wurkkos TS10 (L) vs SP10 Pro LH351 5000K High CRI ®
Also, I noticed many similarities between Wurkkos TS10 and Sofirn SP10 Pro. Packaging, label, clip, and threads.
The clip dimensions are identical to my eyes. However, the clip on TS10 is significantly more stiff.
As mentioned, I would like to see parasitic drain measurements. I also want to see how well its made. I know its cheap at $20 but if its total crap inside, its worthless.
Well… they are cheap, but they are not crap inside. Drain with aux lights on high is excessive, but on low they are fine. On high, IMHO they are wY to bright.
I thought I would regret the first run purchase with cool white odd emitters, but I do not. The tint is amazing, the switch is good. I have ordered more, really excited to get my 4000k in a few days.
Mine was presented to customs on the 7th (hasn’t happed to a light of mine for ages). Will be interesting to see how long it’s there for and what the outcome will be with regards to VAT, as this has already been paid (supposedly) to AliExpress
Wurkkos laboratory confirms to me after repeated testing that Vapcell H10 will not cause TS10 to damage.
The following video is Terry’s personal borrowing two H10 from my laboratory partner to personally confirm the report that can be used normally.
The previously CSP2323 be destroyed, there was a high probability with quality issues.
Link: https://youtu.be/qTyBbwo700w
Hope my report could help with you.
If have TS10 be destroyed earlier, please PM me.
Terry will send the new TS10 and some CSP2323 for replacement immediately, so that you could conduct a testing new.
