Standby drain with red aux on high : 14.5mA to 4.3mA (4.2V to 2.8V) , that’s way too much.
Even ignoring the standby current, it’s too bright.
Anyway please chose a resistor for 1mA max for red/orange leds on high, and probably something like 300uA for green/cyan.
Aux led on during on has been fixed but not LVP for aux (not surprising since hat was fixed after I bought it).
Interesting detail, the body caries the switch signal and the inner tube the cell minus.
Edit : that’s why it doesn’t need any spring load so that both tube make good contact, the switch ring on the front (component side) always makes good contact against the head thanks to the screw pressing the driver onto the shelf (they could also have used a retaining ring), tube/head connection is made by the non anodised threads. The tube is screwed down until the inner tube (batt-) makes contact.
It also means it can be physically locked out.
That’s great news! I’m happy to hear that what occurred with my TS10 appears to have been a fluke probably not caused by the battery and look forward to using the Vapcell H10 in my next TS10 when it arrives.
As others have mentioned the aux leds are too bright when they’re set to the “high” setting, though they’re fine when set to “low”.
However, the “high” setting is the default. Some unsophisticated users may not realize that they can turn the aux leds down to low or to off. they must might just run the light in the default setting. Those users might then think the light is broken if they don’t use it for a few days and then come back only to find the battery is dead.
To fix this in future runs, the maximum brightness of the aux leds should be reduced downward. This can be done by replacing the stock resistor with a stronger one.
Also note: Certain colors appear visually brighter than other colors due to how the eyes perceive colors. This is why current should be limited more for green/cyan than for red.
I could not agree more with your summation. I only use red aux on my Hank lights that get nightstand duty because the other colors are just to bright on low. I only have the TS10 with red aux because I wanted the low mode to be good at night and it is. Does this driver have a pair of resistors, one for low and one for high, or is the PWM set to control high with a resistor for low? I have not had the head of mine apart yet, really glued up tight and I did not want to break it until my 4000k was here.
I assume that series resistor then is on the driver and not the mcpcb?
Found a photo… not on the mcpcb. But it does look like between the first led and the + connection one could bridge one in. May have to work harder to get mine apart. Swapping on the driver would be better as it would not affect both modes.
If you got a dremel with a fine ball-type “dentist drill” bit, you can lightly lightly lightly grind away at the resistor that limits current to the aux LEDs. The more you “hourglass” it narrower, the higher the resistance and lower the current.
Test, repeat as needed. Tedious, unless you wanna measure the resistance first, then decide on a target resistance, then grind, remeasure, regrind, remeasure, etc.
I always figured this worked the other way around. If substrate and coating were removed, I figured resistance would drop. I figured surface area or thickness increased and resistance went up, and composition of the material changed when more resistance was required.
It’s on the driver PCB, likely the one next to the aux wire pad, unfortunately it’s a small 0402 size.
It’s going to affect both modes, it’s not the 0402 resistor or the internal one, it’s either 0402 or 0402+internal, but since the value of the 0402 is small relatively to the internal one it doesn’t affect the low mode much.
Chip resistors are a ceramic substrate with deposited carbon (usually?).
Think of water and 1000 straws bridging a source with runoff. Block or remove 500 straws, and only half as much water flows per unit time.
Same dealy with the C, that by thinning it out, you’re forcing more of a bottleneck, increasing the resistance.
The Pencil Trick does the opposite, by letting graphite be an additional path for current, lessening the resistance.
Metal-film resistors can work the same way.
Wirewound resistors… no. You might abrade away some from the coiled wire and increase the resistance, but you’d be creating local hotspots that might burn out if you push enough current.
That is interesting… way back when in analog electronics classes we never had this discussion and at that point most were thru hole wire wound resistors with low power carbons in a few places. Think very early 80’s, we did not have the tech in school to work with SMD and SMD devices were very rarely used in general electronics at that time. I have loved building with SMD components over the last several years but was really never formally schooled on them.
For me, electronics at the component level are purely a hobby, other than a couple of jobs in the early to mid 80’s. I almost went into electronic engineering way back when, but really did not want to live in a cleanroom and lab coat all my life.
I proposed a higher resistance for reduced aux LED draw on high earlier in the discussion. Wurkkos explained they picked the high output level for visual appeal, and several members spoke up in agreement. I guess this is a personal preference matter where there is no single right answer.
The key point is the the aux should probably default to low for this light from the factory.
A general note for everyone: the red aux LED’s will have the lowest forward voltage and consequently the highest risk of over-discharging a battery. It might also have the highest current draw. The blue will have the highest forward voltage, perhaps enough that it might never over-discharge the battery. This should be moot now that low voltage protection has been added, but I bring it up in case it is useful info for anyone.
You got more turbos without toasting your fingers than I thought possible! I’ve been enjoying this light as well.
What diffuser were you using with the light tail standing on the ground there?
