【TS10V2 Co release soon】Wurkkos "slender waist" TS10v2 copper available next week with 3000k&4000K
We had a batch of I believe Luckysun flashlights that they made improvements suggested but the newer version had the battery tubes too short and even flattops were tight. So they tooled up some longer ones and they mis-matched.
Some lights had different shades on Head-Tube-Tailcap. Was a mess.
Can also remember in the late 1960’s and into 1970’s when Detroit started using those hideous bumper covers made out of some funky pliable rubber (GM called it Endura) and the paint did not adhere the same and faded way quicker than the metal. Basically was ignored by manufacturers too.
mokume and timascus next?
I don’t think anyone would be happy paying for lights that expensive with the new gaps. It doesn’t bother at 30 bucks, but certainly at mokune/timascus prices. I want to see bronze personally. There is not enough bronze and it gets a tacticool black patina.
Recently received my (full) Ti, and as much as i like it, i find the gap between the head and bezel quite disturbing, since its quite big.
Do more people experience this and does anyone have solved this?
Don’t want to be rude but this thread is diverting into: you show me your gap, and I’ll show you mine.
Gave the beadblasted version a quick polish, looks way better i.m.o.
Another thing, the clip scratches the head. Loosening does help prevent scratching, but makes it less functional though.
Congratulations on your new light.
yes, the gap is a common complaint
on my All Ti TS10, the bezel was actually loose and started to unscrew while opening the light to charge the battery.
The gap got smaller when I made the bezel tight.
but the gap was still larger than on my Aluminium TS10…
one person has gone to the trouble of making the mcpcb thinner, in order to make the gap smaller… this is not an easy thing to do, but you can read about it here
btw, the Advanced Ceilings on the Ti TS10 is set to 150/150 by default… I change mine to level 100/150, which is about 400 lumens… I also raise the thermal ceiling to 55C…
you may find this flowchart helpful:
Imgur
Sounds like a bit of randomness in construction.
My blue titanium has uniform color across its entire length. The body tube isn’t a different shade of blue like in yours. Also, my button does not stick at all.
Overall, I quite like this light.
Here’s my handsome man. I’m happy with everything. I don’t notice any gaps. Does not affect light or appearance. Found your problem! She’s gone!
This looks awesome. What did you use to polish? I’d like to do the same to mine! Thank you.
Paint cleaner.
The particular version that i have used;
https://www.commandant.eu/nl/commandant-cleaner-4
I found that more effort can make it even shinier, but for now this is good enough
I used Sunshine Cloth (do not use on the Blue Ti, it will remove the surface oxide color)
Imgur
Thanks for the rec, my blue Ti has the issue with dark spots on the finish so it might be an improvement to polish it off.
Similar to this reddit post:
I have no Blue Ti, cant say for sure how much effort it will take to polish off the color… I hope you get results you enjoy.
It really looks like they don’t have the Ti oxidation process down well. I ended up with two of the blue Ti lights. One is pretty good, the on the second the head is a slightly darker color than the rest of the light.
This is really nice.
7 Thanks
White AL (not MAO) is tight.
Just got my new CuTi and it is awesome! So shiny and pretty.
Sorry if this has been discussed before but I wanted to know if this is a new Anduril feature!
Everytime I turn off the light the aux shines the respective color for battery voltage a second or two. None of my other lights does this. Is it new??
Also 3C for battery voltage flashes the aux now which I think is awesome!
It initially surprised me too. It is something fairly recent in Andruil.
I do like the aux instead of main LEDs being used!
Though I turned it off. I just use 3c to see battery voltage as needed.
A nice feature though.
I also like that the Aux can blink voltage.
Although I wish 3C did not turn on the main LEDs first, before the Aux start the Voltage blinks…
Congrats on your new little CuTi :wink:
