It would be good for a lot of measurements, including battery charging, discharging even with high current, could be used to imr cells, flashlight consumption could be easily measured etc etc
I bought one 2 months ago, still waiting on the last backorder item before my order ships, which I'm expecting to arrive around march this year. Im not expecting too much accuracy in the low current range? (less than 1A) but thats just a guess. Im hoping to be measuring around the 70A mark, but I can see how mine goes when it arrives. Probably be old news be then.. lol, and this thread will be well and truly lost and forgotten....
Just saw the video, maybe its more of an absolute offset, which could be related to the overheads of the unit itself? time will tell.
I'm wondering if you can clarify this device for me. Specifically, I need something that can measure the actual mAh of lithium ion cells. I need to create some basic 4S packs, and to do so requires roughly matching similar capacity cells.
It looks to me like the first configuration diagram on the eBay page would work for me. I'm a little concerned that this will drain down to 0V. But perhaps it has programmable protection? If not, I could add a basic protection circuit to each cell I was testing.
Got my turnigy one. So far its great for high amperage items that connect to large batteries. Anything below 100mA or so it doesn't measure, or so I suspect is the case in my limited testing.
Im planning to be measuring 70+ amps from 3S batteries so its perfect for the job. What is nice is the convenience it offers, where I can connect really any large battery to whatever I'm using. Recently I used it to monitor the voltage of a SLA battery as I was using a portable air compressor. Watching the voltage sag under load, and monitoring the discharge rate and capacity discharged. Informed me of how much the SLA had aged over the years!
