I still havenāt built mine, but now Iām wishing I had ordered a few extra pills and an extra head or two during the group buy.
I finally got my tools out this week, but my weekend is going to be too busy for me to work on it. I only have the two pills. I think one will likely be a simple XP-G2 driven moderately hard. Iām going to dig through my box of parts when I have time to see if I can find any of the old/good emitters, and I may attempt a dedome for this light.
Iāve been eyeing these for a while and missed the group buy. I would love to see some hard numbers on the 78mm head with a dedomed xp-g2.
I noticed you said āattemptā a dedome. Others may disagree but I have had very good luck with adhesive stripper like this: Adhesive Stripper
It is a thick gel so I just put a blob on top of the dome for 10 to 15 minutes then gently blow it off with compressed air. Iāve only done 9-10 but havenāt had a single failure and tint shift isnāt too bad.
I built one of the pills with mine up last night, but Iām a bit perplexed hereā¦
I went with nothing fancy, just a domed XP-G2 1A (new style) and a Qlite. I attempted to focus the beam down to the tightest hotspot for a white-wall shot. I was able to do so, but doing so meant unscrewing the head until there were only about two thread turns left before it separates. Curious if the light focuses better at a distant point (at the intended range) when the head is threaded in further.
(editing to add)At white-wall-hunting ranges, the beam patterns are as follows:
With head fully threaded onto body, beam is compact, ugly, mess.
With head loosened to near-falling-off point, beam tightens into a nice, intense, hotspot. I just need to put some black paint on the head of the pill to get rid of the rings.
Iāll get to take it outside tonight and check it out, unless itās raining, but in the meantime:
If you have to unscrew the lens so far to get a focus, is it possible to machine some material off the pill to set the LED in deeper? or adjust the lens holding ring, and add a spacer to push the lens further out in the body?
What are the LED star and driver board sizes for these lamps?
I paid $120 US Dollars,
this was for
Two x UF-1508ās with 75mm lenses $38.00
Two Extra red LED pills $8.60
Four Panasonic 18650 3400mAh batteries $29.60
Paypal fee of $5.00 USD
DHL express postage $38.80
