Hi Guys
I’m new to the forum and new to Lighting, im not sure if i have posted on the correct board but i have a few broad questions spanning a few topics:)
I’m currently trying to put together a cost effective bike lighting system, but wouldn’t mind some advice.
I currently have two ebay XML T6 LINK
The batteries are only 3.2 V (2 x 18650 in parallel)
I was thinking of changing the battery to an 8.4V 2S2P for each light (hopefully the driver in the Light will accept this)
Im assuming 8.4v is the preffered voltage to run at as most T6 bike lights have 8.4v packs ?
Batt option I’ve been looking at are
4GREER 3100mAh protected
AW 3100mAh Protected
EagleTac 3100mAh protected
A123 LiFePO4
Or a selection of lower mAh rated unprotected cells here..
http://www.allbatteries.co.uk/gsa/result/?q=18650
and then I’m looking to mount the cells in a 2S2P holder either;
Protected (if im using unprotected cells)
Unprotected (if im using protected Cells)(i realise the link is 4P but you get the idea)
I already own a XTAR WP6 charger (should i get a better charger ?)
is there any benefit to charging individually ? or should i wrap the cells and do a make shift charging connector LINK
How would you do it ? is there a preferred setup ? am i on the right track ?
Cheers in advance
