> I put the graphs and charts here if anyone want to check it out
https://www.beesinspace.com/led_spectrums/
thanks for the charts!
really appreciate the R9 info
do you have any info about the R9 value of this Waveform bulb?
An update to my previous post. I bought some high CRI bulbrite brand and had 2-3 go out in a open air fixture. Canāt really recommend those based on my small same size. Too bad
The Philips Warm Glow got updated from 80 to 90 CRI, so the 80 have been discontinued. Are you referring to these or are you saying the 90CRI are discontinued now also?
Both Soraa and Sunlike are violet pump LEDs which for me moot any CRI or DUV issues, the violet pump LEDs iāve experienced have none of the light quality issues iāve spent the last 15 years trying to resolve, they just work and iām transitioning to them wherever feasible. Ideally i would use them exclusively.
The Warm Glow ones have actually been updated again to 95CRI, and in all of the other color temperatures.
Sadly, they are Canada exclusive currently as noted in my post that @jon_slider noted ![]()
https://old.reddit.com/r/flashlight/comments/vk7qmm/very_new_high_cri_bulbs_came_in_philips_ultra/
To answer some of the questions since my last post:
No, I donāt own any waveform bulbs. I read somewhere that they had lifetime / reliabiliby issues, so I bought one Soraa Vivid bulb from 1000bulbs to test only. Also 1000bulbs just lowered the price on them - the one I bought was $24, and now a week later they lowered the price to $18
As I mentioned on the page with the spectrum plots, I found a better deal on them in a box of 10 from prolampsales, so if I decide to get more of them, Iāll get them from there.
I do believe so. This video from Technology Connections on youtube is what alerted me to this. Home depot in the US put them (along with a lot of other philips bulbs) on clearance. I was only able to find one box of 2 warm glow CRI90 bulbs lost at the back of the clearance shelf checking 2 local home depots. The CRI90 ones are still available on Amazon, but it seems like nowhere else. When you go to the Philips lighting webpage about Warm Glow, and hit the button at the top that says āBrowse warm glow bulbsā it comes back saying āNo Products Foundā.
Now, that said, the āUltra Definitionā (CRI 95) warm glow bulbs seem to be rolling out in Canada, and some are available at walmart.com, but neither the philips lighting Canada or US web pages seems to acknowledge their existence. So, is it a new product and the website is not current? Or are they also discontinued and theyāre pushing everyone to Hue / smart āconnectedā junk now?
Too bad soraa doesnāt make 3000k A19, seems like a missed opportunity
Anyone make thermal tests of these lampās ?
Hi,
Thanks to this forum I learned I could do TMS30 analysis using the Osram tool and Argyll, so I bought an old i1 pro on the local Craigslist and processed the Philips LED I recently bought that were claiming 927 spec so CRI>90
Osram LEDStar Classic 75: I bought these bulbs a couple years ago, I always thought they were a little yellowish
Philips Master Value LEDBulb : I bought these bulbs a couple months ago
You can clearly see a red LED was added, which gives CRI 93 and R9 65
Not bad for a couple euros ! These bulbs are āfilament-likeā so they have a large angular diffusion like classic halogen bulbs, which I needed
There is no stroboscopic effect I had with other bulbs
Overall Iām very satisfied, I used to still have all halogen bulbs in my home because I hated LED colors, and only use LED bulbs in summer because of the heat, but this year is the first time I think I wonāt need to go back to halogen in Fall !
Iām trying a bulb I havenāt seen mentioned yet ā the Kaufman BLF10.
Itās an RGBWW smart bulb with upgradable Open Source ESPHome firmware to connect to Home Assistant. It is flicker-free. I donāt have the tools to test the light quality, Iām curious if anyone has tried these?
There have been quite a lot of these over the years but the hackable ones are drying up. Considering how āopenā this bulb is trying to be I would see if you get a reply from the maker about the spectrum. Trust but verify I guess. Too bad itās A21 sized.
I have a pretty big Home Assistant install myself but high CRI/quality smart bulbs are few and far between.
Not exactly a bulb but I got a TV for my media room and decided to try some bias lighting since the room is best used very dark.
6500K is the standard white calibration for film so the best bias lighting (behind TV) is that.
Got a 4 meter open box strip of MediaLight Mk2 from biaslighting.com and can say the CRI is as advertised. 97.8 CRI 88.3 R9 quickly bounced off a neutral light gray wall.
I tried some hue products but they only go to 6000K and avg 80-85ish CRI.
This guy over at reddit tested a bunch of bulbs, and apparently the pulse rate is bad on the Norb Smile. Links to video and charts in the Google spreadsheet.
https://www.reddit.com/r/Biohackers/comments/vbbmzj/how_to_replicate_full_spectrum_sunlight_indoors/
I have Soraaās 2700k ZeroBlue/Healthy bulb, and they have a violet peak to help color rendering without the circadian rhythm hit. I havenāt done any tests and Iām comparing to random store bought bulbs, but Iām happy with it for bedroom lighting.
Comes across as a bit more white/yellow than the orange I get from the Cree 2700k I have.
That's a good find. I shortcut his spreadsheet.
I find it interesting he doesn't mention the Waveform lights in his conclusion, despite testing them. I'm pretty much sold on them everywhere in my house they bit, but it's too bad they don't make some 40W equivalent options for my bedroom.
Indeed. He seems focused on getting full spectrum light and as little blue peak as possible. He did cross-post here and said:
Iām personally pretty sensitive to flicker, so the GE Sun Filled donāt seem like a great option for me, and currently looking at options to eliminate blue peak in the places I spend most of my time. Iāve ordered some of the Shanpu/Flashpu bulbs, and am about to order some of the Sunlike bulbs and will see how I like them.
Iāve got two Soraa Vivid 3000k PAR30ās in my kitchen, and I might just get some of the GE Sun Filled 5000k PAR30ās for the other two fixtures to see how they feel in practice.
I have some results to share.
Phillips Ultra HD, Soft White: (the new Canada bulbs) purchased from Amazon; acceptably 2700k but they noticeably dull bright colors and are yellow-tinted. Not as high CRI as the numbers would suggest.
GE Filled with Sun: about the same as above, perceptually slightly more vivid colors.
Phillips Warm Glow 150W: vivid colors, noticeably on the magenta side of the BBL curve. Totally acceptable at 2700k full power, strange magenta tinted light when dimmed at 2200k, probably straying too far off the BBL curve.
https://a.co/d/e3CljJu
Great Value Soft White spotlights
https://www.walmart.com/ip/515130585
A sleeper hit. 3000k, must be nearly on the BBL curve. No perceptual tint at all, feels like white light. The highest CRI of all of the above, colors are super vivid.
GE Relax HD: About the same as GE Sun-Filled, slightly duller colors.
Took a visit to Ikea and tried a bulb marked āNEWā online.
TRĆ
DFRI
LED bulb E26 800 lumen, smart wireless dimmable/white spectrum globe
205.187.37
I was hoping since it was new it would be more impressive but itās fairly underwhelming. The CCT range is unique since it goes down to about 2200 and up to around 4000. Using Zigbee2MQTT in Home Assistant I dialed in the 2700,3000,3500 etc CCT and at full power itās surprisingly close to that CCT in reality (within 10-15 Kelvin). A bit more variable at different dim settings.
CRI is acceptable but not āamazingā. Around 92-93 overall CRI and 50-55 R9. DUV is above the BBL in all cases ranging from ~0.002-0.0045
I used a frosted glass shade that is open at the bottom to test and you can see the cool and warm LEDās making a fuzzy grid pattern on the glass. I suspect it hasnāt had enough āroomā to properly mix the tint.
Walmart has a sale on some WiZ 800lm A19 high CRI RGB smart bulbs (wifi) so I decided to grab a box to test. 4 for $15, gotta try it despite the fact I hate wifi smart devices. I believe they are made by the same people who make Hue for Philips.
Overall the spectrum is pretty good.
They go from like 2020K to like 6500K CCT and have full colors. I think below 2700 or so they are cheating with Red (630-635nm). Duv varies greatly but itās mostly on or under BBL. The actual CCT is not bang on using the āWiZā app like the Ikea bulbs above.
Thanks, especially for sharing the ArgyllPRO screenshots at various CCTs.
The Ecosmart zigbee bulbs from Home Depot have been hitting a sweet spot for me - Zigbee control, CRI 96-97, 2700K-5600K, R9 80+. But every once in a while, they have this weird flicker/pulse about once a second, and their price has gone up as well. Keeping my eyes peeled for a suitable alternative, and the WIZ are a contender.
Yes the EcoSmart were a surprise for sure. Wish they still made new zigbee stuff.
