but is it possible for me to mod it to run a single 18650 I know I need 6 volts or does anybody know a good 16-17mm boost driver that bumps the volts ?
there is no boost driver to use a single 18650 to power a MTG2 or XHP LED….at least that i know of…
Take that light apart how does it look inside? is the old driver and MCPCB easy to remove…is it glued etc
You could use two 18350 cells if they fit in the tube. But you would loose lot of runtime. Also the XHP50 in a smooth reflector has a donut hole in the spot.
I would swap in a good xm-l2 or xp-l on a dtp mcpcb and a 17mm fet (+7135) driver.
