Ultrafire WF-502B R2 +18650+ charger for $5.69 ...$5.35 after coupon (back to $16.99 again!!!!)
I came across another deal at DD,
its a Ultrafire 502B with R2 led, as in the title. (take note, that the link title actually mentions a Q3)
Dont know how to distinguish the difference between the R2 and Q3 by looking at the pictures....)
Just to make sure, everyone knows, Im not related to DD, but I search on their website almost daily for good deals, and find them once in a while!
Here is the link... only $5.69 with blue 18650 battery and 1 bay charger...
I really dont need it.. but its almost too good to let it go..
anyway, I pass this time (most probably)
If you use the following coupon code, you can get 6% extra off; FONAREVKA price will be only $5.35.
*Thanks Torelu*
If you order over $30, you can use the following coupon code; oneworldweshare to get $5 discount.
if you order over $50, you can use the following coupon code: DDthanksgiving to get $10 discount.
*Thanks MixoMaxo*
I order 2. The drop in alone cost as much as the light.
This is why i love DD. Got to be a smart shopper to really appreciate!!! I got too many crazy deals there and they always honor the price and ship them.
Yes, they have some good deals!
But as I mentioned in my first post.. the title says R2, but if you look at the weblink itself, it says q3... beware!
I was looking for a couple cheap chargers. Guess I'll take the light and battery as bonus ;)
Yes, they are having a so-called Xmas sale.... This is a great price.
The blue Ultrafire battery, it is unprotected. I have a 2400 and another 3800mAh, measured about 1400-1600mAh in capacity @ 1A draw. They can give over 3A. But these cells are not advisable to be used by the newbies, be careful.
But the charger should be good, charge with protected cells and see if they cut off below 4.23V.
Use coupon FONAREVKA for another 6% :) Just ordered 2. Let's see what happens ...
Yep I used FONAREVKA too. If these lights don't have low voltage cutoff (and I assume they don't) they're asking for trouble selling them with unprotected batts eh?
And.. it has only 1 mode! (pro or con, you decide)
Thanks for the code... if anyone knows another code with more % discount.. please share!
ty m8 I ordered 6 for Xmas :D
have also op reflector looks a great deal
using that oneworldweshare u save 5$ if the order is over 30$
DDthanksgiving 10$ off for 50$ orders
...if u order 9 will be 4.6$ each... crazy deal
ChibiM
Can you Copy and paste the coupon codes and put it in your post please?
Okay.. I will
DXADEALS, or maybe it was DXADEAL, is good for 10%. May heve R2 stamped on the body like the WF 504b did, with a different drop in, presumably a Q3 this time. Ordered one, thanks ChibiM.
EDIT: CODE NOT WORKING.
@2pts1scn; sorry, but both the codes dont work! maybe you can use them after a certain amount.. please let me know, so I can add it into my first post!
Don't know what happened to the code. I don't see a mention of Q3 anywhere now, either.
What the heck...I grabbed one too at that price.
You need to look in the address bar.. the address of the web page has Q3.. in it:
here:
ww.dinodirect .com/ UltraFire-WF-502B-CREE-Q3-LED-1-Mode-180-Lumens-Flashlight-with-Battery-Charger
I see. Well, let's hope for an R2. Host,charger and battery at any rate.
I gave it a shot too. Nothing wrong with a q3 anyhow
For $5.35 I'll bite. I don't have a WF-502b anyway... I've never ordered from DD so I setup an account and spend some time on the site which looks very nice. I checked for an XML drop-in for the 502b and only found one and the reviews didn't match the item description... They indicated they were for a MagLite drop-in(?). If the light is well-driven with a good emitter, I may try to drop my 28mm aspheric in to make a pocket thrower. I may just rob the dropin from this host and put it in a WF-501a body with the aspheric and put an XML drop-in in this host...
<edit>I guess I missed something... After I checked out, I noticed that the amount was $7.35; an extra $2 for insurance had been added to the order. Yell
