I mean , with this much output to begin with , a little output loss would be compensated with better color perception , and as far as that goes , while I prefer a tint of approximately 5C , I would willingly accept a slightly cooler high CRI emitter ...
Well, high CRI doesn't really go hand in hand with cool tints-the Rebel is probably the cooler High CRI led I've seen, aside from the Nichia 119, the bestest High CRI led out there, but runs over $40 a pop and requires an application from nichia, and a large order.
Should i buy this Led and a flashlight body (total 28$)
or buy this light? http://www.dealextreme.com/p/ultrafire-ssc-p7-2-mode-900-lumen-led-flashlight-with-strap-18650-50320 or http://www.dealextreme.com/p/ultrafire-wf-501b-ssc-p7-csxo-3-mode-900-lumen-memory-led-flashlight-with-strap-1-18650-1-17670-36356
If you have your heart set on ordering from DX I got this light a couple weeks ago and it has the new DX XML direct drive drop in that is as bright as the Manafont one for $19 bucks. 800 plus lumens.
I can confirm that it pulls more than 4 amps (Fluke 179) from a fresh unprotected Trustfire flame so if you go to this chart that puts it at well over 800.
This drop in has really bad PWN and it's direct drive so the output on high can get dangerously high with good batteries, otherwise it's a great piece. If the KDC8 is still on sale for $16.99 I would get that.
I just got this dropin yesterday and mine only measures 2.0A draw on a TF flames battery. Still beats my DX R2 dropin, so it will do fine for my use and have better runtimes at the lower draw. I see the current medium mode on this dropin as the most used light level.
Would be a good candidate for a Tido's custom mode mod with a new driver. Program for 4 modes so you only have 100% for showing off.
Under driven i would say to foy's but mine are still very bright as and they would get dam hot if the current draw was doubled IMO, The Trustfire Flames take the most mAh.
Checked with two DMM's a fluke and a cheap DSE DMM
