FIREFLIES is an emerging flashlight manufacturer.
The first flashlight launched the ROT66 with 9 high-CRI LEDs.
Please refer to:
Fireflies ROT66, Born for fans of flashlight
then……
Look at the trend of 21700 lithium battery
Also introduced two flashlights using the 21700 lithium battery E07, PL47, are well received
The characteristics of the FIREFLIES flashlight are not only the design but also the appearance.
The most important thing is the rich operation interface.
People who use custom gear shifting and first contact with firefly flashlights may feel too complicated
However, as long as you have a little patience to understand the UI architecture, you will love this flexible interface.
FIREFLIES family portrait
Black carton packaging, golden hot stamping
Boxed content: hand rope, holding clip, waterproof ring, 18650 turn 21700 conversion tube
Appearance is similar to E07, higher height, more heat sink
Power Indicator
Use a 6 degree lens with illumination angle
Tail cover
Detachable same color clip
7 ultra-deep heat sinks
Use 21700 lithium battery, can be converted to use 18650 lithium battery
(Please do not use a power battery that discharges more than 20A)
Exquisite chocolate-like texture of the barrel, strengthen the hand feel
4-eye power indicator
Beautiful deep recessed heat sink
Tail cap
Use SST40W N5 5700K LED
SST40 close-up
Gold-plated spring
Driver
Provide refresh firmware contacts (requires special tools)
Head thread
Tail thread
Luminous angle 6 degree lens (concentrated light)
Lens front
LED PCB
Moonlight
Outdoor test (four level + Turbo)
Scene light
L1: 20 lumens
L2: 100 lumens
L3: 500 lumens
L4: 1000 lumens
Turbo: 2300 lumens
Animation
Thanks for watching
