[Google Translate]
This should be the first Zoom flashlight from LuminTop.
Through the push-pull of the convex lens of the barrel, the poly-and floodlight zoom effect is produced.
The zoom flashlight is very convenient for everyday use.
Can adjust the spotlight and floodlight according to your own needs.
Especially in the mechanical maintenance, there is considerable convenience.
LuminTop’s consistent environmental carton packaging
ZOOM1 (There may be ZOOM2 in the future?)
Double carton packaging
Open the inner box
Intimate thank you card
Boxed all items
Use the head to push and pull, no segment zoom
The head of the tube remains in the last state of flooding
The head of the tube is pushed to the front of the spotlight
The inside of the barrel is exposed ZOOM1 when it is opened.
Look good
After the head is pressed, the height should be almost the same.
One battery attached
It should look like a protected 2600mAh lithium battery
The (bunny) standby indicator light after the battery is installed can also be easily seen in the dark.
Off after power on
Provide Micro USB charging device (Well, not using USB3.0 specification?)
Large spring with tail cap, no magnet
Hand rope hole position, support flashlight stand
The instructions are in Chinese, English and Japanese.
The main feature, LED visual should be cool white
Instructions
instructions 2
Operation flow chart
Structure diagram
Specification Table
Green rabbit during standby
Tube pattern
Mark
ZOOM1
Charging current
Bright red rabbit when charging
Charging complete bright blue rabbit
The wall is about one meter away, and the spotlight
Floodlight
Outdoor spotlight
About the middle
Floodlight
Animation
Beautiful and practical zoom flashlight ZOOM1
thanks for watching
