Mini 16340 flashlight Olight S1R II new listing
Just seeing S1R doing charity sale, by the way, buy it back.
The text is still simple. If you have any questions, please ask again.
All in white carton packaging
positive
Most of the follow-up is S1R on the left and S1R II on the right.
Side, five-year warranty
back
Tear off the seal
Package contents
Flashlight front
Side I
Side II
On the left is the previously purchased S1 mini high CRI
Use different optical lenses
The tail caps are magnetic and the magnetic strength is exactly decreasing from right to left.
Can be firmly sucked
Three small tubes
Insulation protection gasket at the factory
Same the battery capacity, the S1R II’s battery has a stronger discharge capacity.
S1R II battery’s positive insulation protection is more prominent
Ready to do a charging test, powered by DC 5V 2A
The two USB charging cables are used interchangeably. The new charging head is round and thin.
Red light: Charging
Green light: fully charged
S1R II charging current
S1R charging current
If you use a general charger, the positive pole of the battery must be equipped with an magnet to be charged.
CREE XM-L2 CW
CREE XM-L2 CW
The center of the button switch has a power indicator
Green >60%
Yellow 10~60%
Red <10%
S1R’s tail cover
S1R II tail cover
The barrel texture, the S1R II hand feels more clear
Warrant serial number
Streamline
S1R holding clip
S1R II two-way clip
All have a moonlight mode
Lumen test: (steel_ lumen) S1R
Turbo s: 991
Turbo :613
High : 304
Med :76
Low : 7
Moon:no display
Original data
Lumen test: (steel_ lumen) S1R II
Turbo : 1114
High : 678
Med : 85
Low : 12
Moon : no display
Original data:
Different lenses and different light spots
Light spot test I: sequential from left to right
S1 mini, S1R, S1R II
Light spot test II
Thanks for watching
