This is an attempt to get some more insight into the current measurement error caused by the inclusion of the DMM itself, when dealing with high-draw unregulated lights (DD).
Meet my two Voltcraft DMMs:
- One with a 10A range (nicknamed "Ten", to avoid confusion between range and readout figures below),
- and an older one with a 20A range (nicknamed "Twenty").
Using an 18650 unprotected Flame and thick quality leads, I measured the current drawn from battery by my unregulated TrustFire F15 on High. Taking the reading about 5sec after connect for the current to stabilize somewhat, and allowing the setup a 5min rest between measurements.
Battery no-load voltage before first current measurement ... 4.00V.
Measuring with both Ten and Twenty in series ... 2.45A (Ten) and 2.43A (Twenty), i.e. 2.44A (average)
Measuring with Ten alone ... 2.75A
Measuring with Twenty alone ... 3.15A (falling)
Battery no-load voltage 45min after last current measurement ... 3.99V.
Thus, adding Twenty to the circuit already containing Ten, induces a current drop from 2.75A to 2.44A (-11%),
while adding Ten to the circuit already containing Twenty, induces a current drop from 3.15A to 2.44A (-23%).
Considering that the introduction of the first DMM into the circuit (the way current is normally measured) has a relatively bigger impact (exact amount unknown) on current than the introduction of the second DMM (since by the introduction of the second DMM the first DMM has already raised the total circuit resistance), I'd venture a rough estimate that the actual DD current draw is 20-40% higher than measured (depending on circuit and DMM internal resistances).
Also, given the DMM and battery, the more current a direct driven light is pulling, the bigger the relative current drop provoked by the ammeter and thus the larger the measurement negative error.
