【Updated】 Battery Survey with Prizes - XTAR
【Updated】Interactive Battery Survey with Prizes
Dear all, we are on a mission to improve our products and services, and your feedback is invaluable to us. By understanding your needs and experiences, we can make significant improvements to our battery solutions. Please take a moment to share your thoughts with us through our interactive survey.
:point_right:Fill the form: https://forms.gle/LhAUdCVJhvdcuzJV8
We’ll select 2 lucky participants to each receive 4 pieces of 1.5V batteries. Thank you for your participation!
Text
We are so glad to share XTAR 1.5V AAA Lithium 1620mWh battery was released online!
Check more: XTAR AAA Lithium 1620mWh Battery - XTAR
Main Features:
• Strong: Constant High Power at 1.5V
• Fast: 1.9hrs Full Charge
• Durable: 1200+ Cycles
• Genuine: 1620mWh Energy, 1000mAh Capacity
• Considerate: Low Voltage Detection
• Intelligent safety chip, anti-leakage and multiple protections
Nice. What are the dimensions of this cell? What charger is required?
The dimensions(mm): Φ10.3±0.3xH44.2±0.5
You can use xtar 1.5V AA/AAA Li-ion battery chargers, such as L4, L8, MX4…
But you HAVE TO use the proprietary charger, right? You can’t use an ordinary charger?
Yes, for rechargeable 1.5V Li-ion batteries, its principle is a 3.6/3.7V lithium battery stepped down to 1.5V through a regulating circuit module. This built-in battery management system ensures the output voltage of constant 1.5V. For charging these kind of batteries, it needs standard charging voltage around 5V. So the common 3.7V Li-ion or 1.2V NiMH chargers can not charge them properly. It’s suggested to choose the compatible xtar chargers, such as L4, L8, MX4 mentioned above.
【Update】 Interactive Battery Survey with Prizes - XTAR!
Are we there yet?
If you’re looking for testers, I’m a candidate – I use 1.5V AAAs extensively in remote sensors and could use the added capacity when compared to NiMHs. I’m currently using primary lithium cells but looking for rechargeable alternatives, and these from XTAR could be just what I need.
