Updated - XTAR Batteries
XTAR MC1 & MC2 Charger NEW online:
Tiny But Mighty!
• Compatible with protected 21700 battery
• 1A constant charging for optimal speed
• Higher recovery rate for the discharged battery
• Type-C port, charge everywhere
• Multiple protection mechanisms
• Compact size, easy to carry
Congratulations. Seems also to be a great way to juice up my D06 1200 divelight :beer:
But your price is more than twice of your competitor.
Hi dear, may I know which brand you mentioned? This is our xtardirect store link: https://www.xtardirect.com/products/xtar-18650-3500mah-10a-battery?VariantsId=11073
【Updated】XTAR 16340 850mAh 2.5A Battery
This new 16340 Li-ion rechargeable battery has increased capacity by 30% to 850mAh, allows for more power to keep your devices running longer. A output of 3.6V and continuous 2.5A discharge current perfect for LED flashlights and other electronics.
More info online: XTAR 16340 850mAh 2.5A Battery - XTAR
【New Product】XTAR 26650 6000mAh 10A Battery
The new xtar 26650 battery has a 6000mAh capacity with built-in safeguards against overcharging and over-discharging. It has 10A continuous discharge current, ensuring reliable power to diverse electronics, with a lifespan of up to 500 cycles.
More info online: XTAR 26650 6000mAh 10A Battery - XTAR
【Battery Maintenance】Why does storing Li-ion battery at 100% charge damage them?
When you plan to store some 18650 Li-ion batteries for a long time, it’s suggested to charge to a voltage around 3.6V, and maintain at around 40%-80% charge. It’s not suitable to keep the Li-ion batteries at a 100% full charge. It’s because the higher the voltage, the more electrochemically active the battery components are. Some harmful erosion and chemical reactions are accelerated.
Batteries produce electricity through a chemical reaction. High performance lithium batteries use a lithium material that is intentionally designed to be “sponge-like”. In order to maximize the surface area available for chemical reactions. Like the sponge, the battery will struggle to find space for lithium ion once it approaches fully charged. It leads to heat and unwanted chemical reactions with the electrolyte, which converts lithium ions into lithium metal. This can be reversed with discharging. But over time, it may loose available lithium ions and the space to move into. Storing at 100% removes the ability to dissolve the lithium metal during discharge and can become permanent.
And everything is cumulative. Voltage, temperature, time, all contribute to the batteries’ degradation at increasing rates. So if you plan to store lithium-ion batteries for an extended period, it’s best to store them at a partial charge, around 50%. This state minimizes stress on the electrodes and electrolyte, preventing degradation during storage.
【New Product】XTAR 18650 4000mAh 10A Battery
So glad to share we released new XTAR 18650 4000mAh 10A battery! It has ultra high capacity 4000mAh, 600+ cycle life. Check more details online:
# Reviewers Wanted - XTAR 18650 4000mAh Battery!
XTAR 18650 4000mAh Battery Reviewers Wanted!
With 4000mAh, it’s the highest capacity 18650 battery. It has 10A continuous discharge current, up to 600 cycle life, suitable for flashlights and other electronics.
Are you interested in testing it? Just submit your application right now. Entry link :point_down: :
https://forms.gle/e9FZvFNUNk6TNbBVA
YOU WILL GET:
  1. 2PCS XTAR 18650 4000mAh Batteries
  2. Multi-channel promoting your content by XTAR (indicate your credit).
  3. Participate in more collaborations and get free products priority
REQUIREMENTS:
  • The content can be real capacity testing with your equipment, comparison with other brands 18650 batteries, runtime in your devices, or other creative content…
  • Share the review content within 15 days after receiving the product.
The final results will be announced on June 20. Join us now! If you have any question or advice, feel free to message us!
I filled out your form… FWIW
Thank you! Welcome more friends to test our new 18650 4000mAh batteries.
helo! i would like to know if this 10A max cont. disch. 26650 6000mah battery will work on Turbo in L7 Convoy? thanks!
Hi there, this xtar 26650 6000mAh battery is with 10A max continuous discharge. I checked the Convoy L7 online. It says the cells need to have a continuous discharge rating of at least 11 amps. It’s compatible with flat top or button top cells. I’m afraid this 26650 is not very stuiable with this light.
ok thank you! hope u make one with 15 A cont. disch. in future :grin:
So glad to announce 6 reviewers of XTAR 18650 4000mAh battery recruitment below! :blush:
testers - XTAR
We will contact all testers via email for more details. And thanks all fans for your participation!:heart: :heart: :heart: We may run other reviewer recruitment in the future, and will be happy to share it again.
I redacted the real names, please don’t publicly post users’ personal information without their permission.
7 Thanks
June 21 … What i get for playing with Puters …
Looking forward to some results .
4000mAh @ 10A That would be something .
Will we ever see an 18500?
New Product - XTAR 14500 1200mAh 2.5A Battery**
New XTAR 14500 1200mAh 2.5A battery was released online! [image]
  • 1200mAh Genuine Rated Capacity
  • 50% Longer Runtime in Small Lights
  • More Than 500 Cycles
  • 3.6V 2.5A Reliable Power
  • Safety Protection Circuit Board
More details online: XTAR 14500 1200mAh 2.5A Battery - XTAR
