USB Charger with Batteries for GPS Unit
Hello :
This is my first message in this forum so i want to congratulate for this great forum. :wink:
I have a GPS Unit with internal battery (Garmin Edge 800). On March i have prepared a track about 18 hours, and the autonomy for GPS Unit is 10 hours about. My GPS Units charging with 5v, from computer USB or wall charger.
For this reason I would like to get a USB charger for batteries 18650 (i have 2x Panasonic 18650 3400 mAh), and so I would charge the GPS Unit while cycling with lossing datas.
Please, i am grateful to you if advise to me for a good device for this.
These are the options that i have seen :
Option 1 : http://www.fasttech.com/products/1421/10002784/1535101
Option 2 : http://www.fasttech.com/products/1421/10002784/1535100
Option 3 : http://www.fasttech.com/products/1421/10002784/1381305
Option 4 : http://www.fasttech.com/products/1421/10001919/1137904
Option 5 : http://www.fasttech.com/products/1421/10001919/1158900
At moment, I likes Option 1, but i don’t know if it is the best option.
Note : I don’t need charge 18650 batteries because i have NiteCore Charger.
Very thanks you beforehand.
Rafael.
I would go for option 3, I have one of those ENB-Tri power bank, and it works very well with panny 3400s. Does everything I want of it.
And should do what you want to do with it.
I also like option 3. And because it is easy to take the cells in and out, you could also use it as a charger.
Thanks for your answers. :slight_smile:
I have only 2 batteries 18650. That’s a little problem.
Do you think that Option 1 (with 2 batteries) will be enough for charging the GPS Unit ??
Thanks.
Option 3 will also work with only 2 cells
I can't find it yet, but I think I read in some of the FastTech discussions or Reviews where the 2x ENB box won't take Protected 18650s. I also have the triple-cell ENB charger from FastTech (The model with the 5mm LED instead of the Cree). I've only had it since last week though and can't comment on using it yet. I used it to charge my mini Android tablet and it seemed to work well for that. Yes, it will work from two cells, but I would understand wanting to minimize size for biking...
I have the ENB 3 cell but with the added Q5 flashlight. Working great! I've used it to charge the cells and that has worked well. It will work on 1 or 2 cells and will take protected batteries. I too also remember the 2 cell versions only working with unprotected cells.
-Garry
Check out HKJ's reviews of usb battery boxes. Some of them don't fair so well.
Thank you very much to all.
Helios, i’ve just read those reviews, a excellent information. Take this when deciding. Thanks. :wink:
In fact, i would like to minimize size for biking.
Anybody has used the model for the Option 1 (only two cells) ??
-Rafa
