I am starting to use more rechargable Li-Ion batteries for my new found flashlight interests.
There are a few questions I like to straighten out, if any one can help offer some insight.
The higher the rated amperage (capacity) the battery can last longer, but will it push out more current?
For 18650, the limiting factor is the ability to charge beyond 4.2V for those newer high cap >3000mAh for it to attain maximum potential, otherwise a lower capacity battery is preferred because of less cost? or ?
Many lights cannot fit 18650 due to ID (unless bored), therefore the ‘thinner’ options like 17670 & 16650 exist.
However 17670 & 16650 is far less capacity compared to 18650.
The main concern for protected cells are for their longer size not fitting into chargers properly, but in a flashlights this is easier to solve due to the spring.
What will be a perfect charger then? Would you say it is the Nitecore i4 v2? I dont think this i4 charges beyond 4.2V though…
*How about using 16340 X2 , wouldn’t 2 cells give a higher voltage (7.2V) than just 1 18650 (3.7V)? Therefore the lights run much brighter?
Can I assume 16340 X2 draws more current, which is an amazing benefit!
My thinking is given less run time (lower capacity) of 16340 in exchange for a higher voltage and current, thus a brighter light.
Therefore going 18650/17670/16650 X1 defeats my purpose of having a strong and powerful beam.
(In my applications, I like the light super bright (max) for about 80 minutes. Recharging afterwards is ideal for me.)
How about using 2 CR123 primaries? I heard CR123 x2 is still the best brightest option that exist, True? Why?
