I have mentioned several times, here and there, usually in the context of my IR illuminators i built when i talk about my scratch-built night vision? That i have built several “multiple lens” illuminators. One is a dual lens setup, one is a 3 lens, another is a 4 lens.
It was a several month long journey. I am fairly sure what applied to LED IR emitters, also applies to visible LED emitters…the big difference would be i was working with IR and therefore one main centroid wavelength (mainly 850nm) and if memory serves me, our visible emitters have 2 or more wavelengths. Other than that, and the refraction differences, they should be very similar.
There will be “some math”, but really, its nothing THAT major. If you took “college prep” in high school? i am sure you have more than enough math under you to follow the plot line. Algebra I + II, some geometry, a little trig here and there, and youre golden.
The PURPOSE of this, is to form a sort of “white paper” that will allow you to easily begin using 2 lenses, and i will end it with a description of how if you can use 2 lenses fine, then you can use 3 or even 4 lenses. I should note? while following the math is HELPFUL, its not NECESSARY. I found, the math got me a quick start, and after i had run the math enough times? i began to be able to simply pick up lenses, focus them on a CFL twisty to draw up an image on white notebook paper to judge the 2 lenses FLs… and can simply use them and “play” to design something.
heres where it started… i had the idea, a strong hunch… that using more than one lens would be “better”. Cameras/telescopes/monoculars/binoculars/microscopes… all use more than one lens, my GUT told me i should be using 2 or more lenses to focus light up at distance… but HOW?
i got 2 thin biconvex plastic lenses, out of the “eyepiece” of an old cheap BBGUN scope (4x fixed) and fooled around and got them to make a cheap keychain laser to grow bigger and smaller on the wall… so, i knew it COULD work, but… i was like a kitten playing in the dark with a flashlight beam (pun intended). I had to find some MATH to understand it, or this would take forever.
Also? i had to first find SOMEwhere, that it was the proper idea to use 2 or more lenses… i first had to QUALIFY the idea, then i could try to QUANTIFY it.
so… the first thing i found that told me i WAS on the right track? a white paper from edmunds scientific, heres the link…
Equation 1 ? basically sets up a “NA” or “Numerical Aperture”, which to ME seems about like an F-number in photography. It relates the diameter of the lens to the focal length (D to FL), and provides you a “figure of merit” to compare some things, among them the width of the LED emitter beam and lenses you might want to try.
the first several paragraphs on page 1 of this white paper? Really doesnt do much for us (yet)… but it DOES cover what we all already know here… that to try to illuminate something brightly as possible really far away? using a single lens is the first idea, and its a good idea… also, we all know already that a higher FL makes for a smaller beam that appears brighter and goes further, but, only up to a POINT.
also, that increasing diameter of the lens is good. After equation 3, we see the devils dilema we all know about already… that increasing the diameter of the lens is good up to a point (where it begins to get ridiculously wide diameter) and that you quickly want a longer FL, but, as the FL starts to get “really useful”, you are too far away from the LED, and you lose a lot of light that doesnt “cut” the lens.
its all a DANCE, and we can only “do-zee-do” a certain amount, before we start running out of usefulness… so, what comes next? By the third column on page 1, we see they quickly introduce “step 2”, which is of course, using a second lens! Yippee! (I was happy to find my idea QUALIFIED, as in, some “pro” somewhere thought this was a great idea, too)
The rest of the paper goes on to introduce arcane stuff, such as light pipes and weird arrays and stuff, not terribly useful to me.
Using a scientific calculator, and they are available online too… all the equations on page 1, are easy to simply “plug in” values and get results. ONE of them i think gives the size of the focused emitter (in radians, which converts to degrees easily enough)
TECH TIP: from experience? i can tell you that figuring numerical apertures of lenses and emitter half angles? is not TERRIBLY useful at your bench… i find better quick results from setting up the lens, and blowing cigarette smoke into the visible beam approaching the LENS focused up… you can easily see the beam then… and a piece of white paper after the lens will quickly tell you if you are “losing” a lot of light that is not cutting the lens…
before we really get started? we REALLY need a quick, easy way… to discover the ACTUAL focal length (FL) of any lens we pick up, buy, or salvage…
THIS link will tell you how, and its pretty easy. You cant just focus up on the white wall, and measure from the back of the lens to the LED, thats only the actual distance from the back of the lens AT THAT DISTANCE. We mostly all know that even a single lens has a RANGE of focus, and that it changes. Its shorter at long distance focus, and much longer up really close… this link will tell you how to find the exact “real” focal length…
http://ronja.twibright.com/faq/focal_length.php
you will want to know this for the next part… getting started with 2 lenses…
