Hi everybody, in a nutshell, I want to build a single emitter, high current light from this SRK-like host (except no e-switch) that has 1s4p cells, and I've decided to keep it in this battery configuration, so I'm limited to 1s voltage ranges.
Here's the host from fastech this version is known as the SME-4628 :
https://www.fasttech.com/products/0/10020308/4368900-sme-sme-t628-led-flashlight-gift-set
It's a 46mm driver size and I already have mtn electronics 46mm linear driver, basically a giant Nanjg style 7135 driver. discussed in this thread:
https://budgetlightforum.com/t/-/27369
and found at mtnelectronics here:
http://www.mtnelectronics.com/index.php?route=product/product&product_id=270&search=46mm
The driver shelf and led shelf are not very far apart, so I've ruled out piggy-backing a boost driver for an xhp-50 or something, although that would be better and I plan to do that with a different light in the near future. I just feel keeping the light in 1s configuration without having to mod the reflector etc is much easier and more geared towards my skill level at this point, so let's just assume the light is going to be single cell voltages without a boost.
I plan to run an Xp-L2 at max 5A by removing chips from the normally 12a mtnelectronics driver and Rmm has kindly agreed to flash the driver with firmware to use without an e-switch.
http://www.kaidomain.com/p/S026187.Cree-XP-L2-HD-V6-1C-White-5700K-LED-Emiitter
My question is basically to check my understanding and decide if using a linear driver with plenty of battery overhead (for example, four 25r's in parallel so each cell is only having to give ~1.25ah) is the best choice here. This light will be used as a tool for seeing outdoors, navigating a boat, and 'cause super bright lights you make yourself are cool of course, otherwise I'd just buy something off the shelf. I wish there was a perfect buck driver for this situation, but its a unusual size driver and small driver cavity, so options are limited.
But back to my question, I figured choosing the linear 46mm instead of the Fet direct drive version is the best choice with the low Vf of the Xp-l2 from a practical standpoint, If I'm going to use the light out in the wilderness and not just to make the brightest flamethrower I can. Is this a correct assumption? Or will the lower Vf of the Xp-L2 cause the 7135's to heat up excessively? All of this is assuming I can really improve the thermal path of this light via adding copper around the led and reflector, silicone thermal pads, and whatever else I can come up with or copy from others on here. If you were going to build a high current single emitter light with 4 parallel cells, is linear and the Xp-l2 the way to go?
Or, would a different LED like the Xm-l2 or Xp-l hi serve better from a Vf standpoint? I know the xp-l hi would throw better, but this is going to be an all purpose flood/spotlight so really I'm most concerned with matching the driver and LED correctly for efficiency over throw/beam pattern, and I think the Xp-l2 would be easier for me to get right in the reflector vs the Hi version.
After scanning the forums as much as I could to try and understand the relationship between Vf and battery current in linear driver, I was wondering if anybody would care to give their opinion on this setup and if it could be improved while staying within the parameters of 1s cells and either an Xm-l2 or Xp-l2 size emitter. By the way, the led will be on the 32mm maxtoch dtp board and I'm going to do as much potting of the driver and additional copper as I can manage, and the host has decent mass and cooling fins, so hopefully the 5a will be handled well, even though it won't be used on 5a for longer than maximum ~60seconds at a time. Is 5a a pointless gain in lumens for the heat it will generate?
Thanks for taking the time to read this and add anything you care to. Also, lots of thanks to all those who post their testing results and opinions on here, and spend hours and lots of money to test these things. Too many to list, but it's been extremely helpful and informative.
Unscrew the tail cap to reveal the switch board:
not the cleanest, but I'm getting better.
