Utorch UT01 and UltraFire batteries
A beginner’s question.
I was looking at picking up a Utorch UT01 until I read that they don’t take protected 14500s. I have some UltraFire 900mAh batteries with PCB on the label that measure a hair under 50mm. What is it about these batteries that would keep them from working in the Utorch?
There’s a ton of info about that light here on BLF, but basically the problem is that the battery tube is very short.
There is a strong likelihood that many lights have been damaged by putting in a long battery and damaging the driver and/or switch by screwing down the tail cap forcefully.
The work around is the ‘paper clip trick’ (better served with copper wire or thin solder, but search BLF) and/or clipping most of the coils off the outer spring in the tail cap.
But seriously, search BLF - this has all been discussed here in great detail. It’s a terrific light with one major flaw that is fortunately fixable with minimal effort.
The Utorch UT01 is a defective light. Too many issues with the switch
Yes, I’ve seen that some are bad. But apparently some are good too. Do you know of a more dependable flashlight that size with a side switch only in that price range?
Thanks for the response. I did look here about the light, but there’s a lot of common understanding among most people here about batteries and such that I don’t possess. I’ve read about batteries that are longer than 50mm, so I thought my Ultrafires were on the short side.
I just did a search on the paper clip trick, and I encountered something I often do here. In some posts with photos, I just get graphics that say that 3rd party hosting has been disabled, and that I need to unlock my account. What’s that about?
Check on the Klarus Mi7. Its available with code for $20.
Take a look at Sofirn sp10b. I got mine for about $12 and change with free shipping from Amazon.
But honestly, I still like UT01 better. Both of mine work fine. I suppose my opinion would have been a lot different if they were not working.
They should be able to fit. I have some AmazonBasics AA Nimh cells that are 50.2mm long, and they fit fine in both my ut01 lights. I have since trimmed the springs a bit in both lights as it was a little tight in there, but even before the trimming they fit.
Thanks.
Thanks.
Maybe the Sofirn SP10a
Thanks. Someone else recommended the SP10b. From just a quick look, I think the B adds a moonlight mode. It’s available on Amazon for around $16.00.
Sofirn has been monkeying around with naming and firmware. I think the new SP10A uses the exact same UI/firmware as the SP10B, so there may not be any difference between them.
Just keep in mind, the moonlight mode on Sofirn SP10A/B is more like a firefly mode - very very low. Personally, I don’t like it that low, but others do.
+1 on the sp10b. Very bright and easy to carry . It is my EDC , well, will be when Sofirn replaces it. Protected cells fit it . The firefly is very low for my liking .
My protected Sanyo cell (EVVA) fits in my SP10B, but does not work. Not sure why.
I looked at reviews here on the 10a and 10b. The reviewer of the 10a said there was no moonlight and listed just three lumen levels. I didn’t know which one Amazon had because it just said SP10. Since it does have the 1 lumen moonlight, I think it’s the 10b.
I think they all use the same UI now (b). I use the fenix 14500 , 800 mah protected cell .I think it is $6.95 with free shipping from Fenix . Ships from USA so it is fast .
I have two of the Sofirns. They work perfectly for me and I just use Eneloops. Problem solved and you don’t have to worry about whether your protected 14500 is too long or questionable or whatever. I think output is what it needs to be - I don’t need to scorch my eyeballs all the time. I do have 14500s but just don’t like the idea of using them in something that is going to get tossed around and dropped.
my efest IMR cells are 50mm exactly and theres no problem. You should be fine there.
The real problem with these lights is the dodgy switch quality and reliability. You are better off with a different 14500 capable light IMHO.
I think the thorfire TK05 deserves a mention, I dont have first hand user experience with it though.
Thanks. I’ve been looking at that one too.
