steel_1024
(steel_1024)
1
He Ain’t Heavy, He’s My Brother
I prefer the EDC05 shape, but also the tail magnet, more practical.
11.27 sent, 12.27 received
The following are EDC05 on the left and UT01 on the right
EDC05 is higher, probably, Because of the added magnet
EDC05 have tail magnetic
XP-L Hi & XP-L
EDC05 is a stainless steel pressure ring
The same UI
Even the same warranty! ?
The same tail, double spring, can be interchangeably
The same driver
The same switch
Of course same
Hand rope hole
6500K
djozz
(djozz)
2
Nice comparison, even more parts are identical than mentioned thusfar.
A bit worrying that they have the same switch+driver, I hope that it does not imply that the EDC05 will have the same switching problems as the UT01?
niraya
(niraya)
3
I think the original is best option :partying_face:
joechina
(joechina)
4
Has the EDC05 the same problem with protected batteries as the others? Too short tube.
steel_1024
(steel_1024)
5
I tested with AA & 14500
These two flashlights, ALL fine.
kramer5150
(kramer5150)
6
Nice… the XPL HI in the EDC105 should throw a tighter more concentrated hot spot (all else being equal). Do you observe this?
Does the EDC05 have user selectable mode brightness like the UT and E11?
