Just do some reading around here and you’ll get an idea real quick on how it’s done. If you can’t solder, find a friend who can solder those two wires for you.
I host my M2 host and 1 amp driver from RMM who post here. His store is http://www.mtnelectronics.com/
Don’t forget the tweezers . They help with putting the LED in place and are perfect for screwing the driver retaining ring in place.
EDIT:
I used this driver . I used the M2 host because it was just easy to screw a star down with 2 screws. The M1 host should be just as easy.
I also bridged #2 star to ground ring to disable the “disco inferno” mode.
EDIT 2:
(-) 1, 2 and 3. Any one can be used.
(+) 4, 5 and 6. Any one can be used.
EDIT 3
MCPCB star sits in here, held down with screws. Wires come out of the other two holes.
Driver sits in here and is held in place with a brass ring.
I hope that is a good enough explanation.
