I have been experimenting a bit and noted that normal plastic lenses as used in both most prescription glasses and inexpensive drug store reading glasses seem to block virtually all the light output from 365nm ZWB2 filtered UV flashlights. A flashlight aimed at normal bond white paper, that fluoresces quite noticeably in a UV flashlight beam does not do so if the beam is shined through the glasses lens before reaching the paper. Also a glance at the LEDs in a ZWB2 filtered UV light covered with a plastic glasses lens look red rather than blue. All this indicates to me that the material in normal plastic glasses lenses should work fairly effectively for UV flashlight eye protection. The red LED appearance looks to me like the red that per the article on UV flashlights from 1LUMEN that ZWB2 filters let through in their tests.
A Google search for the following link also verified that Polycarbonate plastic does filter UVA and UVB light.
https://www.google.com/search?client=firefox-b-1-e&q=polycarbonate+uv+filtering%3F
To me this indicates that virtually all plastic glasses lenses should provide considerable protection from UV sources including flashlights. I hope that members find this information useful. A quick test of your glasses is to get a sheet of bond paper that fluoresces when your UV light shines on it and then shine the light through your glasses lens. No visible fluorescing then the lens is providing considerable UV protection.
