KLARUS 360X3
All-new 360º "Switch Ring" Tactical Flashlight XHP70.2
- The 3rd generation tactical tail dual-switch. All-new 360º "Switch Ring" for omnidirectional control molded from premium grade soft silicone; high elasticity yields larger operation area for quick and accurate reaction.
- CREE XHP70.2 P2 LED with max output up to 3200 lumens (with included 18650 battery), far exceeds the competition.
- Easy Interface: One-Touch Strobe, One-Touch Turbo, One-Touch Low, Mode Memory Function, SOS, Switch Lockout Function, Quick Change Settings.
- Incorporates multiple breakthrough technologies: Intelligent Thermal Protection System (ITS), Intelligent Battery Identification System (IBIS), Intelligent Charging System (ICS), Multiple Safety Systems.
- Patented tail cap dual-switch and side switch design, adaptable for different scenarios, easy to use.
- Two Interfaces: Tactical Setting; Outdoor Setting.
- Tactical Setting: Specially designed for self-defense and tactical use. Classic KLARUS XT series control interface. One-Touch Strobe; One-Touch Turbo; perfect candidate for any mission.
- Outdoor Setting: Designed with the wilderness in mind. One-Touch Low; One-Touch Turbo; Multiple output levels, SOS function; suitable for all needs in Hunting, Hiking, Camping or Search and Rescue.
- Intelligent Thermal Protection System(ITS): monitors and auto-adjusts output levels in real-time, keeps LED and crucial component safe for the best balance of performance and safety.
- Intelligent Battery Identification System (IBIS): Adjusts output according to the currently installed 18650 battery discharge rate, compatible with 18650 Li-ion batteries, CR123A batteries and Klarus 16340 batteries.
- Intelligent Charging System (ICS): Micro-USB charging port with real-time monitoring of charging status to prevent overcharging. Max charging current limited to 1A (avoiding damage to charging devices), ensuring optimum charging status.
- Multiple Safety Protections: Over-Charging Protection, Over-Discharging Protection, High Current Protection, High Temperature Protection, Reverse Polarity Protection, Impact
- Both tail and side switches can be put into lockout mode, this prevents accidental operations; stops battery drains during storage or travel and avoids eye injuries.
- Springs at bezel and tail end resist shock and drop damages.
- Reverse Polarity Protection eliminates damage from incorrect battery orientation.
- Aero-space Aluminum alloy body with CNC machining; Mil-spec hard anodizing (HA III); lightweight yet robust construction.
- Stainless bezel ring offers protection for crucial components and can function as an emergency glass breaker during emergencies.
- Integrated light head design for high efficiency heat dissipation.
- Tempered glass lens with scratch resistant AR coating.
- Premium quality soft silicone embedded into the flashlight body, achieving tactical slip-proof grip with max comfort. This design excels at improving light retention in extreme cold environments.
If you are interested, notify in this thread (not in PM)
