Has anyone tried or use these 26650 cells? I am looking for new cells for my 26650 torches, MF01 MINI, D4SV2 and FT03… I currently use the purple Efest 4200 cells but these Vapcell’s look good
Vapcell 26650 5300mAh 20A G53 Battery (Gold)
This cell is the King of the Ultra-High Discharge/Drain cells in the 26650 form factor size. They make 5,300 mAh in capacity of energy, while having a true Maximum Continuous Discharge/Drain Rating of 20 Amps. That’s a fabulous blend of both energy and power combined in a cell. These cells also have a very good life cycle as well. These cells are typically used for vaping at higher demanding amperage and also for very highly modified or custom built flashlights with multi-emitters and/or single emitter flashlights that use a FET/DD type driver in them. This cell can also have other useful purposes in other device(s) as well, as long as the device(s) are compatible with this cell’s dimensions and within its performance specifications.
Specifications:
Model: 26650-5300
Style: Flat Top
Nominal Capacity: 5300mAh
Continuous Discharge Rating: 20A
Nominal Voltage: 3.7V
Protected: No
Rechargeable: Yes
