For the latest version of this Vapcell S4 + charger (V 2.0?), can the charge and discharge currents be user selectable while running the Repair function in manual mode?
If not, then what are the charge and discharge currents, please?
Thank you.
Thank you.
Hello, repair mode. The repair current of lithium ion battery cannot be selected. The maximum current is 250mA
When the repair is completed, it can be taken out and the appropriate current can be selected by selecting the charging mode
Thank you for this information!
I have just ordered a Vapcell S4+ charger, which I believe to be one of the better universal chargers presently available.
Thank you very much for your support. Where did you purchase it? It seems that there is no distributor in the Netherlands
Purchased via AliExpress on 7 June. Awaiting shipping.
I am in New Zealand (NZ).
Thanks
Hi @vapcell_Dennis - I’m just giving the repair function a first spin.
How do I know it’s done?
It’s running simce 24hrs (at least I think so), the battery icons are still moving.
And is there a way to tell how long it would or will take?
Thanks!
I recently purchased a Vapcell S4+ V3 charger and received it just yesterday. After going through the previous topic titled “Test/Review of Vapcell S4+ Fast Charger,” I came across a test conducted by HKJ. In that review, it was noted that the older first version of this charger displayed the internal resistance as being only half of the actual battery resistance, which raised concerns about its accuracy.
Given this, I wanted to ask if this issue has been resolved in the newer V3 version of the Vapcell S4+ charger? Does the V3 still have the same internal resistance display issue, or has it been improved for more accurate readings?
I appreciate any insights or experiences from others who have used the V3 version.
Thanks in advance!
